Author Topic: Aircraft ID Q's  (Read 4727 times)
MrT
Aircraft ID Q's
« on: November 10, 2009, 07:21:18 AM »
I often notice that  when hovering my pointer over a particular aircraft icon it fails to update and reflect the aircraft details, but instead displays a totally different aircrafts info.
Any idea why this is? Does anyone else have this problem?
Re: Aircraft ID Q's
« Reply #1 on: November 10, 2009, 07:41:29 AM »
Not with Beta V3.08 :-)
Even with earlier versions, if this happens, just move the mouse pointer away and back over the aircraft then it updates.
MrT
Re: Aircraft ID Q's
« Reply #2 on: November 10, 2009, 07:50:02 AM »
Thanks Allocator,
I'm running 3.08 but will try that.
Maybe its just my sluggish old laptop!
Cheers,
Paul.
MrT
Re: Aircraft ID Q's
« Reply #3 on: November 10, 2009, 08:03:23 AM »
On this subject,
I recall that in Airnav Suite, you could drag the tag id around and out of the way of other tags and position it where you wanted. I wonder why they dropped that feature ?
Re: Aircraft ID Q's
« Reply #4 on: November 10, 2009, 08:25:12 AM »
You still can.  Press the SHIFT key while moving the tag around.
Re: Aircraft ID Q's
« Reply #5 on: November 10, 2009, 08:47:08 AM »
On this subject,
The aircraft labels automatically move to avoid overlap, so you won't need to use this unless you want to.
MrT
Re: Aircraft ID Q's
« Reply #6 on: November 10, 2009, 09:18:32 AM »
Thanks guys.
