Author Topic: Diagnostic software for RB ?  (Read 3981 times)
MrT
« on: November 21, 2009, 12:31:32 AM »
Would it be possible to write a small utility program to test and monitor the RadarBox performance ?
Re: Diagnostic software for RB ?
« Reply #1 on: November 21, 2009, 12:51:33 AM »
Not sure what you mean, Can you explain what you mean by performance?
MrT
« Reply #2 on: November 21, 2009, 01:11:09 AM »
I was thinking of some way of seeing what offers the best for antenna performance/placement?
To offer a way of locating your antenna for best results when installing? That kind of thing?
And to just do a diagnostic report that all is functioning as normal ?
Just a basic diagnostic tool, kind of like old modems used to have.
I have had my RB for nearly 2 months and still not sure its working 100%
My antenna is located indoors and I get a lousy polar diagram. I have taken it outdoors, with no better results.
I figure I need a better antenna or maybe there is a problem with my unit.
I won't really know till I shell out $400.00 for an antenna kit (which I can't afford just at the moment).
Just be nice to know that all was working 100% before I needlessly send it back for repair/replacement
« Reply #3 on: November 21, 2009, 10:09:31 AM »
Did you take your antenna outside with a laptop, or by just extending the cable?
MrT
« Reply #4 on: November 21, 2009, 10:15:37 AM »
I took the laptop, RB, and supplied antenna outside. Made little difference.
I was in the backyard with houses all around though.
Im sure its just my location, not the RB or antenna.
« Reply #5 on: November 21, 2009, 10:21:18 AM »
Best way to check if your Radarbox is performing 100% is to find a hill, and test that you're getting around 200 mile range on the polar chart when sat on top of the hill with your laptop and antenna.
« Reply #6 on: November 21, 2009, 10:21:40 AM »
It's well worth taking your Laptop and RB to a slightly more open area.  The difference should be very noticeable.
Clear the Polar diagram and then select it on and watch it build up as aircraft are detected - it will give you a quick idea of any improvement in range.  If you can't get out in the open, then go up!  Putting the antenna on the outside window ledge upstairs should produce an instant improvement.
I've got that energy saving glass in the windows and the screening affect is very noticeable.
Got to go shopping now :-)
MrT
« Reply #7 on: November 21, 2009, 10:26:55 AM »
Thanks guys,
Im sure that I just need a better antenna or open area.
Will try it out tomorrow.
