FTP transfert dont work
Started by Jonathan.G, November 23, 2009, 10:51:20 AM
Not sure I understand.  Are you saying your ftp server can only cope with active mode?  As I say, it works perfectly well for me, uploading to ftp.gofreeserve.com/htdocs/shot on port 21.
Maybe use Wireshark to see what error messages are being returned by the ftp server.
Jonathan.G
Ok i have the error :
501 port address does not match originator.
Quote from: Jonathan.G on November 23, 2009, 04:04:57 PM501 port address does not match originator.
Is that when doing an ftp to the gofreeserve.com ftp server?
abrad41
Janathan.G
There must be something wrong with your settings - as tarbat has said, there are a few of us on here who uses gofreeserve and all of ours is working fine.
Try to use gofreeserve again, as I said all of ours are working fine.
Andy
Fenris
Google says the 501 FTP Error means that "server returned an invalid response to PASV command, [try to] select the USER@SITE FTP method instead of PASV method".
One thought.  What version of Radarbox are you running?  I remember there being some ftp problems with earlier versions.
Jonathan.G
i have the last version 3.11
same problem with 3.07
Jonathan.G
i have found on google the "501 port adress does not match originator" error
because the program dont upload the .GIF in passif mode !! its a bug...
i can upload on the ftp with FILEZILA, and i cant with ANRB ...
Quote from: tarbat on November 23, 2009, 04:14:32 PM
Answering this question may help understand your problem.
Jonathan.G
#24
so....its a transfert bug via ANRB....i have a new ftp and dont work too
i have check the transfert with WIRESHARK and wireshark say :
Request : PORT 127, 0,0,1,6,217
Reponse : 500 Illegal PORT command ANRB.EXE
Its just bug of ANRB with the passiv mode
Just add a passive mode for transfert in ANRB and the transfer will work...
(Sorry for my english.....)
abrad41
Just try and use gofreeserve again.
As I said before, several of us use it, so cannot be a bug in ANRB
Jonathan.G
TRY TRY TRY ... -_-
same error..... just add a passive mod in ANRB  !!! its a BETA version ! its time to add this !!
PASSIVE MODE TRANSFERT AS FILEZILA
Well, I'm lost now.  We've suggested using gofreeserve.com as a test, and I really don't know if you've tried this or not.  Can you not just answer the question - do you get this 501 error when uploading to gofreeserve.com?
Others have no problems with ftp in Radarbox, but I'm starting to think you maybe don't want our help getting this working.
Jonathan.G
Yes i have the 501 Error with gofreeserve.com same problem with free.fr, iceheberg.fr, voila.fr, ifrance.fr      All FTP have the 501 ERROR with ANRB transfert
With FILEZILA all FTP WORK and with ANRB the transfert FAIL ( error 501 )
abrad41
Did your settings in gofreeserve look like the one's below.
