Author Topic: "Select All" in Alerts or SmartView Setup  (Read 4791 times)
pwfu
    • Follow me on Twitter
« on: November 26, 2009, 10:31:18 AM »
Hi All,
You can't do Ctrl-A in either of these, which is a bit of a pain in the rear end when it comes to SmartView for me as I have quite a lot of aircraft loaded in, and recycle the info quite often.
Is there another way around this rather than me sitting there for ages, or is this something that maybe Airnav can add quite easily?
    • Rod's RadarBox Downloads
Re: "Select All" in Alerts or SmartView Setup
« Reply #1 on: November 26, 2009, 11:38:06 AM »
In each of those boxes, you can click at the beginning of the first record, then press Ctrl-Shift-End to select all of the entries for copying.
You have to do it for each of the boxes in the Alerts, but at least it does work.
pwfu
« Reply #2 on: November 26, 2009, 11:39:49 AM »
Thanks Rod, I'd tried a few combinations before, but that works perfectly!
