RadarBox 3D (4.00) Ready for Beta Testing
Started by AirNav Development, November 28, 2009, 01:32:10 AM
The date everyone was waiting for has arrived.
After 5 months of development RadarBox 3D is finally ready for beta testing.
A few points:
1- We named this version RadarBox 4.00;
2- It launches as any other RadarBox software. After the connect button is clicked it checks our server for RadarBox 3D activation: if active it launches as RadarBox 3D. If the server cannot be contacted it is launched (by default) as RadarBox.
Download link:
http://www.airnavsystems.com/Download/ANRB/400Beta/ANRB400BetaSetup.exe
Please keep all the discussion on this thread.
pjm
#1
I'm getting odd white blocks over parts of the aircraft & also instead of my "home" location. I've circled them in purple...
Is there supposed to be a /data/assets directory in this version, if so its missing...
pjm
Copying over an old assets directory fixes the white block problem for both aircraft & home location.
pjm
Preferences dialog and Help box & Weather screen, etc  are falling behind main screen after a while...
pjm
FTP upload of 2D screen not working. May be related to above "split screen" activation and dislogs falling behind main screen, Because there is some 2D screen uploads from before switching to split mode.
pjm
latitude/longitude/altitude (etc) infobar at bottom of 3D screen is so dim as to be unreadable...
pjm
pjm
prbflight
AirNav Development...the link to the beta exe is not working.
Paul@cyyb
pjm: not all liveries all included (it would be impossible). Anyway if you make a list of major liveries that should appear and aren't let us know. Maybe we can choose 50 liveries that should be there.
prbflight: try again now.
pjm
#10
Random spikes in height - I have actually seen this in the text interface of the 2D version as well, it becomes far more obvious in 3d though.... possibly some sort of sanity check or averaging required for the line drawing....
AirNav 3D Development
@pjm, can you duplicate/post the steps for making the 'preferences' dialog fall behind the main application? I haven't been able to duplicate with this this build yet.
@pjm - Those are great shots of the height point issue. We're working on adding a filter to try and ignore those points in the 3D plots. This should be fixed soon.
pjm
Quote from: AirNav 3D Development on November 28, 2009, 03:52:59 AMcan you duplicate/post the steps for making the 'preferences' dialog fall behind the main application? I haven't been able to duplicate with this this build yet.
So far its a one out of one. I've tried to duplicate it for about an hour without success. No doubt it will re-occur - we just have to work out what sequence triggers it!
pjm
When you select the 3D settings from "3D View/3D View Settings" it takes you to the 3D settings pane in preferences, but the tab is missing from the top. If you select one of the other preferences tab, you can't get back to the 3D settings directly.
