Author Topic: TRA, Control zones etc.  (Read 3411 times)
defcon333
« on: December 10, 2009, 02:30:46 PM »
hi all,
first of all the new version works well.
my question is: living in southern germany i would like to have map that e.g. displays army ranges or TRAs or control zones. how can i achieve this. are there prefab maps that can be used or do i have to create a map myself and if so which software has to be used to get it done and fit it into rb?
any help appreciated. btw i am not a pc expert!!!!
regards
Terre
Re: TRA, Control zones etc.
« Reply #1 on: December 10, 2009, 05:40:43 PM »
you might want to take a look at the links/tools mentioned in this thread:
- http://www.airnavsystems.com/forum/index.php?topic=3168.0
Basically it's done by using outline files (*.out), which you place in the folder named "outlines" of the airnav radarbox software. Files in that folder will be shown on the map.
Either
use existing outlines, found at:
- http://www.sbs-resources.com/downloads.html (install and then see folder "files" for all *.out files required)
- http://jetvision.de/sbs.shtml
- http://www.homepages.mcb.net/bones/SBS/Utilities/Kinetic_Utilities2_Outlines.htm (no outlines for germany)
or
create your own outlines using "Jordans outlinemaker"
- http://www.acme.com/jef/outlines/
