New User + some questions
Started by Marinus, January 06, 2008, 01:20:51 PM
Marinus
Hello All,
Just purchased my radarbox a few days ago and I'm very glad with the way
it performs and with te flight data presented to me.
However I do have a little problem with the my log feature, for whatever reason
it always starts with 90 entries after startup, I then have to clear these old entries
via preferences > radarbox > clear my log entries, would like some help with this....
And on a personal note, greetings to Andre Brandao (hope I'll log you one of these
days)
Marinus Bergsma
Lemmer, The Netherlands.
Hi Marinus,
We have just tried to replicate your issue and can't seem to do it. Is anyone else having the same issue?
Marinus,
There is an issue with the RadarBox software version 1.3 which is probably what you are running.
A software bug prevents your "MyLog" data being saved at the end of each session, so each time you start RadarBox, you will have the same data in MyLog.  Unless you clear these entries manually, any Live aircraft you pick up will be added to what is already there.
This issue has been corrected in V1.4 (due to be released soon) and all your Live aircraft are added to MyLog correctly.  Also, the database has been rewritten as an SQL database with additional functionality.
See this thread for the V1.4 manual and a detailed description of the new database.
http://www.airnavsystems.com/forum/index.php?topic=353.0
You can also download the new manual in PDF format here:
http://www.airnavsystems.com/forum/index.php?topic=394.0
Marinus
#3
@ Support
Have resolved the issue myself, have deleted a D009.dat file dated 05052007 from
the data directory which contained the data that appeared in the my log after startup
after deletion startup = with a empty log !!
Anyway, thanks for the quick reply to my mail !
@ Allocator.
Indeed using version 1.3 that came with the radarbox, have resolved the issue myself
as you can read above.
Eagerly awaiting version 1.4 then,  the SQL databses will be a relief since tempering
with any database with all Airnav software (adding,editing etc.) results in the program
getting corrupted or behaving bad.
