RadarBox 3D 4.01 Ready for Beta Testing
Started by AirNav Development, December 21, 2009, 02:12:22 AM
CAM
Airnav,
Sorry for the delay xmas got in the way !
The dat files I have are shown on the attached.
CAM
#16
Same issue as described earlier by CAM regarding the 3D view not showing.  Test Build V3.04 exe file still works fine, but the 4.01 Beta build just shows a grey window.  This might be a server side issue as I has to get 'reactivated' for 4.01 to run with the 3D options rather than defaulting to 2D?
Scroll to the right to see the grey 3D window below.
RNAGG
As reported previously continue with the problem of Preference option is hidden when I'm in 3D mode. When I go to the 2D mode can not access normally.
Also the screen continues to appear even when it had cleared earlier.
So far these are the problem I'm having in 3D.
pjm
anyone else getting this message when they try to start ANRB3D ?
Frank
abrad41
RNAGG
Quote from: pjm on January 01, 2010, 07:26:25 AM
I´m too receive this message!
I guess that the Beta test software has time expired then.
GlynH
Quote from: Allocator on January 01, 2010, 05:18:56 PM
As have the Developers? ;^)
Happy New Year to you all!
Kind regards,
-=Glyn=-
Give them a break, it has been Christmas :-)
I'm just back at the day job today - the whole office was closed for 2 weeks - you wouldn't have got much out of us over that period :0)
EI4GXB
We are finishing a new exe which should be ready by the end of this week. We will then make it available on this board and it is, of course, not expired.
Frank
Just to report a minor bug. In 2D the Home Location is correct. In 3D the Home Location is wrong. This effect occurs because I use Dutch Regional Settings, in stead of English Regional Settings. When I change to English Regional Settings the Home Locations are the same and correct. It does not effect the plotting of the aircrafts on the map though.
See Attachment.
Frank
