Author Topic: RadarBox 3D 4.01 Ready for Beta Testing  (Read 6087 times)
« on: December 21, 2009, 02:12:22 AM »
After several changes and tests the application can now be considered stable (no freezes, no memory leaks).
The new exe can be downloaded from:
http://www.airnavsystems.com/download/anrb/401Beta/anrb.exe
Now we need you to post on this topic any problems you may find so our 3D Development team can have a look at them.
pjm
  • RadarBox Beta Testers
Re: RadarBox 3D 4.01 Ready for Beta Testing
« Reply #1 on: December 21, 2009, 04:07:11 AM »
Seems ok to me too.
from testing so far with 4.01b
Bugs
  • FTP upload of 2D screen not working unless the 2D screen is displayed and it has focus
  • Aircraft info boxes don't always stay on the screen for the "timeout" value
  • Random height spikes (high & low)
  • When moving the 3D button cluster from its default position other button clusters are displaced and the "Split View" button disappears
  • Google earth plugin always has a fraction of the screen invisible which requires you to use the scroll bar  to see - should be sized to include the "reload plugin" button and info without scrolling.
  • In pilot view aircraft recent trail points appear BEFORE the aircraft's location
  • Google Earth interface - inconsistent altitude attribute definitions cause display errors in other than  "Elevation Exaggeration = 1" configurations.
  • Some models/liveries missing (see separate thread)
  • Welcome Screen randomly returns at startup despite checkbox having been unchecked
  • KML Manager can't locate/load KMZ/KML files
  • "Aircraft from back" view no longer follows aircraft, but remains at initial view location
  • Preferences pane sometimes opens with focus under main ANRB window and is not accessible - requires Alt/F4 to regain control of main app
Suggestions
  • 3D screen FTP upload
  • User selectable FTP upload interval
  • ANRB to remember state and size of "Split view" across shutdown/startup instead of always starting in 3D mode only
  • ANRB to remember setting/size when using 2 monitors across shutdown/startup
  • ACARs to remember "connect" status across shutdown/startup
  • 3D Polar/height diagram (with on/off button)
  • 3D Radar rings (with on/off button)
  • Option to define our own SMTP server to send logs/alerts
  • All changed options should be saved & restored (remembered) across restarts of RB
« Last Edit: December 22, 2009, 04:42:25 AM by pjm »
« Reply #2 on: December 21, 2009, 04:36:10 AM »
Tks pjm. Other beta testers please try to send us a similar detailed list of the bugs you find so that we make our final comments and compile a finished version.
pjm
« Reply #3 on: December 21, 2009, 05:22:31 AM »
AirNav - can you tell me how to make the local KML/KMZ files visible in the "External KML Manager" window so I can load/display them in the 3D plugin?
Scratch that - it worked in earlier versions - I've added it to the bug list above.
« Last Edit: December 21, 2009, 07:16:27 AM by pjm »
Frank
« Reply #4 on: December 21, 2009, 12:13:09 PM »
This update does not make any difference on my system. Still freezes etc.
Frank
« Reply #5 on: December 21, 2009, 02:52:41 PM »
We need the feedback from more beta testers. Frank you will be contacted soon.
RNAGG
    • Aerococus
« Reply #6 on: December 21, 2009, 05:43:29 PM »
Hello!
In the 3D view still having the problem of the Preferences window into hiding, unable to access it.
I'm testing other features and inform the result later.
prbflight
« Reply #7 on: December 22, 2009, 01:46:37 AM »
I've just downloaded the new exe but I can't connect to the server.  Is it down right now?
Paul@cyyb
« Reply #8 on: December 22, 2009, 03:26:14 AM »
The server has been restarted. Up now.
pjm
« Reply #9 on: December 22, 2009, 04:33:27 AM »
This just happened to me again too for the first time in a long time. I'd just turned on the network and was looking at some aircraft over Switzerland, and I'd just successfully bumped up the Network detail to "maximum". A minute later went to check the setting and the preferences pane was popping up under the main ANRB app.
Added to bug list above.
Airnav - I also noticed this version has the beta_log file enabled again, so I've sent it to you, along with the ANRB.elf file in case there is anything to help identify the problem.
RNAGG
    • Aerococus
« Reply #10 on: December 22, 2009, 03:52:05 PM »
I'm not getting into the RadarBox 3D. I'm getting a message to activate the account in 3D.
Therefore, I can not make the other tests.
Next message attachment with my User
CAM
    • http://www.planedaft.co.uk
« Reply #11 on: December 22, 2009, 08:06:47 PM »
Sorry but 4.01 does not work at all in 3d for me ? previous versions were OK cannot get the 3D map to display at all.
CAM
« Reply #12 on: December 24, 2009, 02:46:24 AM »
RNAGG: pls send me a PM with your RadarBox serial number.
CAM: what is the name of the only .dat file you have on your RadarBox 3D folder?
« Reply #13 on: December 25, 2009, 04:44:42 AM »
We urgently need more feedback on the latest exe from other beta testers. Those who already reported some problems will be contacted in 48 hours with more questions.
abrad41
« Reply #14 on: December 25, 2009, 09:49:32 AM »
Airnav
Quote
Bugs
Suggestions
I have all the above bugs
Andy
