Author Topic: Damage from nearby transmitter?  (Read 7629 times)
ww7y
« on: January 02, 2010, 04:37:20 PM »
Anyone damage their RB by using a nearby transmitter i.e. ham radio at 100 Watts within feet of your outside antenna?  Anyone doing this without problems?
Thanks,
Steve - WW7Y
Jeremy
  • Jeremy
Re: Damage from nearby transmitter?
« Reply #1 on: January 02, 2010, 04:43:21 PM »
Yes. No Probs.
J.
G4DOQ
G4DOQ
QRZ.com
Dean
  • Plane photographer
« Reply #2 on: January 02, 2010, 05:18:19 PM »
Yes & No.
My 40m dipole is next to my Airnav antenna - anything above 40 watts temporarily kills off the Radarbox and I need to reset by USB out/in cycling. No damage has been caused.
All other Amateur Fq's cause me no problems.
Dean G8YTC
cq59
« Reply #3 on: January 02, 2010, 05:25:59 PM »
No probs using Icom 746 de G3INQ
Jeremy
  • Jeremy
« Reply #4 on: January 02, 2010, 06:21:43 PM »
Yes. No Probs.
J.
G4DOQ
and at 400 w, no probs.
It will no doubt depend on how much RF you have in the shack!
J.
G4DOQ
QRZ.com
charlie
« Reply #5 on: January 02, 2010, 07:31:18 PM »
Again YES and NO
When I tune my FT450 on 15m (using 35 watts on data psk or rrty) it wipes out my Navbox.
I don't use 15m that often so not a problem.
All other bands and modes no problem.
I have my Navbox and radio shack in VERY Close together (a matter of feet).
When using Voice (max 50watts) on 20,40,80 metres NO problems at all.
Charlie
2E0VDS
Jeremy
  • Jeremy
« Reply #6 on: January 02, 2010, 08:01:51 PM »
again - an RF problem. Make sure the USB lead is a good quality screened one. That made all the difference for me.
J.
G4DOQ
QRZ.com
ww7y
« Reply #7 on: January 03, 2010, 02:03:20 AM »
Excellent info,  I was just afraid of frying the front end on the RB and having to send it all the way to the UK for repair.
Thanks,
Steve - WW7Y
BobR
« Reply #8 on: January 03, 2010, 03:16:08 PM »
I have experienced some loss of contacts on the RB when using my HF on 20m, but I think it all depends on your setup in the shack as most people have commented on. Main thing is that I have not damaged the black box!
All the best,
Bob R
(M6KLO)
Fenris
« Reply #9 on: January 03, 2010, 05:15:22 PM »
But then, as an M6 you'd only be transmitting 10 watts Bob wouldn't you?
BobR
« Reply #10 on: January 06, 2010, 10:44:52 AM »
Yes I am pumping out a huge 10w (often less). I have seen some drop outs if I am transmitting for any length of time such as when I am using the BPSK modes etc. I think as I progress through the licences I will probably turn off the RB when on higher power just to be on the safe side.
Incidently its interesting to see how many people who are using RB are also licensed.
Cheers,
Bob
Jeremy
  • Jeremy
« Reply #11 on: January 06, 2010, 11:29:40 AM »
You will be better off sorting out the RF problems. If you are suffering at 10w then you will have big problems at a higher power and I would suggest you have a high SWR somewhere.
J.
G4DOQ
QRZ.com
radarspotter10
« Reply #12 on: January 06, 2010, 11:34:19 AM »
Thanks,
Steve - WW7Y
No problems here i am using yaesu ft100d and a few 2meters 70cm handhelds
G5RV 100 watts.
radarspotter10
« Reply #13 on: January 06, 2010, 11:46:35 AM »
hi Fenris
I have a saying in my life, "if its illegal you must be enjoying it"  goes back to my CB days when CB was illegal the world over.
The problem is nobody will go near a m3/m6 unless there causing interference, same as radio scanners at the airports there illegal but cause no interference.
from pat
« Last Edit: January 06, 2010, 12:26:26 PM by radarspotter10 »
