Author Topic: Alert Notification Box - size adjustment?  (Read 4586 times)
Tramline
« on: January 19, 2010, 05:15:17 PM »
Hello,
I've just dowloaded V3.13 which appears to be working well (my thanks to 'dca' for his help) but I've had to change a few settings but the Alert Notification Box does seem bigger than before??  Can the Alert Notification Box be reduced or customised in size please?  And if so how?
Located 2 miles South of LHR.
    • Rod's RadarBox Downloads
Re: Alert Notification Box - size adjustment?
« Reply #1 on: January 19, 2010, 05:17:36 PM »
Hi Tramline
I hadn't noticed it being any different - and I'm afraid there's no way of changing it at all.
Tramline
« Reply #2 on: January 19, 2010, 05:23:15 PM »
O.K Thanks Rod.  Does seem bigger on my V3.13
My alert notification box IS different to V2.01 in that the Mode S code is in brackets after the registration i.e alongside it, rather than under it?
« Reply #3 on: January 19, 2010, 05:35:00 PM »
Yes - you're right - I meant the size and function!
I do wish there was a button on it to take us straight to the plane in the grid and on the map. Maybe in the next version...
Tramline
« Reply #4 on: January 19, 2010, 05:38:21 PM »
Yes I was referring to the ability of reducing the size of the notification box.
I'd also like the option as you describe to take you straight to the map where the alert aircraft is flying!
« Reply #5 on: January 19, 2010, 07:54:44 PM »
Intelligent use of the Fleet Watch function does just this.  Double clicking on an aircraft in Fleet Watch takes you to that aircraft.  I use wildcards in the FW setup to track all the BAW B744/777 and all the A380's.
« Reply #6 on: January 19, 2010, 08:26:15 PM »
True - but this evening I had an alert for squawk 7700, and it's a bit of a pain trying to find that!
« Reply #7 on: January 19, 2010, 09:07:42 PM »
I either use the QuickFilters is such a case, or just sort by SSR code and quickly scroll up/down - OK, so not ideal, but functional :-)
