Buttons freezing
Started by milaw, February 19, 2010, 08:35:55 PM
milaw
Hi All
Had a problem crop up,
when in 3D mode,and go to the top bar  3D view and select 3D settings all the buttons freeze on screen  although the list updates and the aircraft move,only way out that i can see is to go to task manager select GE plugin and close the process,then reload it again from the screen that is generated this solves it, it has now happened several times
regards
Malc
Try switching off Network Processing and then try again.  If you have an older PC, it might be struggling to process all the Network traffic.
milaw
Do not have the network processing turned on
Malc
OK, try setting the 3D Preferences for MyFlights to minimum.
milaw
Still does it when minimized
for info task manager shows  (running planeplotter in upload only)
the Ge plug in cpu 55   mem usage 101342k
planeplotter 8 cpu approx 3512 k memory usage
cpu usage 55%
commit charge  1040m/8034m
No idea then I'm afraid.  Have you tried running RB by itself without any other programs?
What is the spec of your PC?
milaw
Thanks for trying,
Specs are :-
  Pentium 4 CPU 3.4ghz
2 gig ram
Radeon X550/and X550 secondary graphics card
regards
Malc
AirNav 3D Development
Quote from: milaw on February 19, 2010, 09:27:46 PM
Thanks for trying,
Specs are :-
2 gig ram
regards
Malc
It sounds like your PC is capable of handling the 3D. What version of Windows are you running? Do you have the latest Internet Explorer installed too?
milaw
Have windows XP SP3
and Internet explorer 8
Have been trying different things but it only happens when using the 3dview setting button
the screen blips then the buttons freeze the the 3d view settings box does not appear,it works ok when using the selected aircraft options tab and others
(now no other programs running)
Quote from: milaw on February 19, 2010, 10:00:22 PM
Have windows XP SP3
It sounds like it might be that the 3D View settings dialog box is flipping back behind the main application window. Can you try next time to un-maximize the ANRB3D application so it's a fairly small sized window and move it off to one side of screen, then choose 3D View -> 3D View Settings and see if it tries to stick it behind your main application window (since you made your window small, it should give you room to see what is happening), you should be able to hopefully drag the 3D Settings window out and click on the settings buttons and finish with "OK" or "Apply". Let me know if that seems to be the issue.
milaw
Top marks
did as suggested and that works .
regards
Malc
milaw
Looks like I have to un-maximize the ANRB3D every time I want to access the 3dview/settings button.
no other way to do it after it freezes
Does it do the same thing when you choose File -> Preferences -> (3D View Tab) ? This is a very strange issue since it's very specific to certain PC's. If you have any ideas what might be causing it on your system, please let me know so I can fix it in the next update.
milaw
It works ok when taking that route( File -> Preferences -> (3D View Tab))to the 3d view/  settings box.
As yet no idea why its doing it(will keep looking)
HDKey
You may find either holding the ALT + TAB keys or WINDOWS + TAB keys to "rotate" the hidden form to the front, as an interim workaround. (Not sure which Windows version you are using). This may save you minimising/restoring.
Apologies if I've missed the point of this thread.
Phil
