Hardware Sometimes Not Connecting
Started by abrad41, February 24, 2010, 09:17:39 AM
abrad41
Just recently when I start RB for the first time, I am getting "Hardware Checking" (See Below) down in the left hand corner, It stays like this until I restart RB, then seems to be aright.
This morning I had to restart RB about 6 times before it would show "Hardware Connected", and a couple of time's instead of showing "Hardware Checking", it was showing "Hardware Not Connected" (See Below).
Any thoughts from anyone including Airnav would be good, is this a case of a hardware going to fail shortly.
Andy
Check your USB lead first, change it and see whether it improves. If not get back to us.
abrad41
This sometimes happens to me.  I just unplug the USB lead, count to 2 and plug it in again.
Seems to happen if I've been messing around with one of the many other USB devices I've got connected.
abrad41
Thank you Gary
I will try that, as I am using a usb extender and I do think you use one too.
Andy
Yes, I use a Maplin purchased Cat 5 type extender with about 15m of Cat 5 cable.  This doesn't happen very often and I'm sure that it's because I'm doing other stuff rather than being a RB issue.
abrad41
Gary
I use the same extender with about 10m of cat 5 cable, but this do seem to be happening everytime I start the RB for the first time. My cat 5 cable does run up the outside of the house, but I did buy special outside cable, my RB box is in the loft. When I get a chance I will get it down and try it on my laptop and see how we get on.
Andy
johnboy
Andy,
        I get this a lot, i just unplug from laptop refit ,works ok. thinking of try a new usb lead,as this has been discussed on another thread also it could be my usb port as the connection seems sloppy and doesnt happen as often when connected to my main pc.
John.
abrad41
Quoteabrad41
Sr. Member
« on: 24 February 2010, 09:17:39 » Quote Modify Remove
Andy
I have been doing some testing on this subject. As I said before I use a Cat 5 type extender with about 10m of Cat 5 cable, running from in my conservetory, up a outside wall, through the outside wall into the loft.
1 - I checked all of the connection from the back of my computer right up to the RB box in the loft, everything seemed good and I still had the problem.
2 - At the RB box end, I changed the usb lead, still no difference, still taking me 3 - 4 starts to get RB working.
This made me think it must be my outside Cat 5 cable
3 - So I brought the RB down to my main computer and tried the Cat 5 extender with a normal ethernet cable, things were still the same
4 - So then straight from the RB into the usb port on the back of my computer, still the same, taking 3 - 4 times to start.
This had me confused, so I thought the only thing left was to try v3.13.
And would you believe it - it work fine everytime - so this leads me to believe the problem is within v4.03.
Any comments would good and AirNav what is your view on this.
Andy
abrad41
For everyone info.
I think I have solved the problem above, I have been running a Western Digital 1TB My Book World Edition backup network drive and the software that came with it, which was "WD anywhere backup software.
When the software is running and backing up files, it will not let the RB start, but as soon as I pause all backups RB will then work, There must be a conflict between the 2 bits of software.  This is just to let you know about this incase anyone thinks about buying one and having the same problem.
Computer Specs are
Windows 7 64bit Home Premium
AMD Phenom II x3 720 3 Core Processor
4 GB DDR3 Memory
Nvidia Geforce 9800 GT 1GB Ram
Hope this helps others
Andy
dxman
I had the same problem, sometimes when switching of the lights in my room the radarbox disconnects.
being a hamradio amateur I had the same problems when transmitting on HF, the radarbox disconnects and I had to pull the plug out of the pc, wait 2 counts, and plug it in again to get it working.
So the radarbox is sensible for glitches and HF transmissions.
And now the answer to these problems: I now use an usb cable with chokes on each end ,(from my digital camera) it lookes like I solved the problem, do some tests tomorrow.
Airnav should supply these leads with their radarbox.
Erik
marcdeklerk
I have this problem when I'm using my US Navigator interface, seems RB and Navigator don't like each other, I have to disable all the navigator drivers in device manager before I start RB otherwise it won't connect my RB.
Once my RB is running I can connect my Navigator and enable the drivers , then all ok.
In my case have to do with the drivers
Hi Erik and Marc, perhaps this is more closely connected to the quality of the USB lead's screening?
dxman
Quote from: CoastGuardJon on March 22, 2010, 05:55:17 PM
Hallo Jon
I used the supplied lead and that gave the trouble so I replaced with a lead from a digital camera with has a choke at the end , and that solved my problem so far.
I dont know if the supplied lead is of good quality, it seems not.
The same problem appears with another  pc and the usb mouse (logitech)when I was transmitting on HF (mouse pointer was moving all over the screen), looks like the cable picks up HF power caussing the problem,so I`ll try some chokes here also.
Hi Erik, I've dismantled 3 standard antennas, 2 out of the 3 had very poor screen (about 7/8 strands very loose and ineffective) sheath in the co-ax, the one Glynh sent me is very much better quality with foil as well as supporting strands outside.    If the antenna leads can be of such low quality, I would assume the USB leads are probably much the same, built to a price!    My original lead was totally U/S, but W&S did replace it when I sent it back with my RB for its second defect (new pcb fitted), but like you, I'm using one from a digital camera.
