Long hold in the snow at EGPE (Inverness)
Started by tarbat, February 24, 2010, 11:26:36 AM
Near blizzard conditions at Inverness EGPE, with this EZY153 from Luton in a long hold and descent from FL260, awaiting clearance to land in the snow.  The phrase "ever decreasing circles" comes to mind!!
Pinza
Thanks for sharing those images, Tarbat.
Probably the most impressive 3D images I've yet seen from new ANRB version.
Look forward to capturing similar images myself - but am struggling to make progress on my upgrade payment...
Chris
eicjf
Where can I find the 3d aircraft. I put the upgrade in but only get map pins? Everything else is 3d?
James
Use the 3D Setting option to change the graphics settings from Minimum to Maximum.
At Minimum, you get the colored spheres.  Medium gives you 2D aircraft symbols and Maximum gives you the 3D aircraft.
