Loss of network
Started by johnboy, March 06, 2010, 12:19:18 PM
johnboy
Box on screen red (network not connected) only receiving my flights.Internet connection ok,new USB cable fitted & all lights lit on RB. Been like this for 3 days,working ok then came to switch on again the fault appeared. Have removed AVG security although i have airnav files\systems set as excluded files on AVG,still the same.Network box ticked,and downloading photos on my flights,also not running 3d. Have contacted airnav support awaiting reply but thought one of you guys might have the answer.
We had to reboot the server a few minutes ago. All should be Ok now.
johnboy
lost the network 3 days ago, still the same now.
Quote from: johnboy on March 06, 2010, 02:21:26 PM
You haven't been able to connect to the Network for 3 days?
Must be a problem at your end?
johnboy
Everything working ok with pc, just prob. with RB network.
Is it poss fault with RB.
No, if you are seeing local MyFlights aircraft, then your PC can 'see' the RB and the Network will work - unless there is a firewall issue, or a problem with your account.  What does it say when you look at your account details using the RB menu option?
AVG is an anti-virus program, not a Firewall.  Are you running the Windows Firewall?
johnboy
Windows firewall is turned off, my account is valid till  Dec.2010
Do aircraft photos, registrations, and routes download okay?  Try doing a weather lookup - does that work okay?
johnboy
Photos,Reg. Routes all ok and getting weather reports ok.
I think that suggests an Airnav account problem.  Suggest you contact Airnav support directly by email.
johnboy
Cheers for that Tarbat,have sent email acouple of days ago re prob.
Roadrunner
Has the Network gone down please?
I can get the web site but unable to get 3D on start-up
Mike
cool_1
I have the same problem right now.....   If you launch Airnav (which worked fine with 3D yesterday), the option has disappeared from the top of the 4.03 Radarbox application window.   Real time network is working fine however...
- any ideas ?  ( Ive tried rebooting ...and can only assume its a server issue)
harvey
Hello,
I got the same problem this morning. 3D isn`t available any more. If i restart the program the 3D icons in the menuebar? disappear after one second.
harvey
We can confirm that our server is working at 100%. No problems reported. SO this has to be a problem on the clients side. Please contact our support and they will help you.
