Opinions on aerial please
Started by bratters, March 13, 2010, 02:24:41 PM
peteeds
Hy, Bratters, looks interesting but the word Directional would tend to put me off as you are trying to receive a moving object unless of course you intend to try & increase your receive from a specific direction, Is it possible that it can be used in conjunction with an existing antenna, I would not think it was possible on the other hand I could be wrong. Lets see what the more technical guys on the forum have to say.
Cheers de Peter 2W1 FJZ.
Neilman2424
hi ,
a directional antenna would only enable you to pick up in one direction and most likely a little off the sides and to the rear of the antenna depending on the side and rear lobes. an omni-directional antenna is the way to go. i purchased the Mode-S / ADS-B antenna from DPD Prouductions
http://www.dpdproductions.com/page_vhf_air.html#adsbout
This antenna works very here is a screen shot taken today and i dont use a pre amp and the antenna is mounted in my loft. my elevation is only a few feet ASL.
the antenna comes packed very well and delivery time is very good from the usa.
hope this helps
