Author Topic: MyLog - entries from May 2007  (Read 8011 times)
« on: February 11, 2008, 03:35:56 PM »
I understand that MyLog doesn't save aircraft between sessions.  However, whenever I startup Radarbox there's already 90 entries listed in MyLog, all with a date of 5th May 2007.  Any ideas how to delete these?
Re: MyLog - entries from May 2007
« Reply #1 on: February 11, 2008, 04:02:45 PM »
Preferences - RadarBox - Empty MyLog Entries.
If they still return you can delete the mylog database file and when it is restarted it will create a fresh one for you.
« Reply #2 on: February 11, 2008, 04:04:52 PM »
Tarbat,
This is what you need, read down to the last post:
http://www.airnavsystems.com/forum/index.php?topic=399.msg2782#msg2782
I'd backup the D009.dat file just in case!
« Reply #3 on: February 11, 2008, 04:58:33 PM »
Thanks again Allocator.  I'd tried the option in Preferences to empty the log, but it didn't work.  As per the link you provided, deleting D009.dat worked.  Thanks.
Wayne
« Reply #4 on: February 12, 2008, 07:14:28 PM »
I had the same problem as Tarbat with old log entries and have cleared old data. Just one very simple question on saving log entries. I understand that when I close RB I will lose data in My Log, could someone please remind me how to save data from each session ?
Wayne
« Reply #5 on: February 12, 2008, 07:48:43 PM »
Wayne
Wait for V1.4 to be released :-)
Wayne
« Reply #6 on: February 12, 2008, 07:54:59 PM »
Ah yes, forgot that bit !
prbflight
« Reply #7 on: February 13, 2008, 03:15:44 AM »
Wayne
Use version 1.2  That's what I've been doing.  Ver 1.2 saves your contacts but will not download photo's.  I also import all my contacts into All Heard Management of Airnav Suite.
Paul
