History?
Started by jasper37, March 22, 2010, 09:05:40 PM
jasper37
got 3d working on win 7 pc
transferd over navdata.db3 and mylog.db3 files from ver 3.13 Vista Pc to the data folder in 3D win 7 pc so the aircraft history etc can be seen in the new 3d version but for some reason no history
seems to be showing only stuff logged today
anybody any ideas whats wrong?
thx for any comments
Jasper
jasper37
Any help from support re this plz?
not had any other comments
Jasper - sorry, I haven't a clue - if you copied the Mylog.db3 file correctly, like I assume you did for Navdata.db3, you should be able to see your history. Once you've checked that, I can only suggest that you contact Support and raise a ticket.
jasper37,
If you right click on the icon and select run with administrator. Do you then get to see the old data?
jasper37
Many Thx Rod for your help
Yes support when i right click....... run with administrator.
i do see the old data
thx
