Sotware Update to 1.3 - Cant Find Driver File?
Started by markyeulett, February 12, 2008, 11:09:03 PM
#15
Quote from: markyeulett on February 13, 2008, 03:29:19 PM
Allocator - thanks but same problem when I try to load from system 32 directory.  What I cant understand is this file is an uninstall programme?
I'm not quite sure how good you are with computers, so I din't really know what to advise here.  If you select the ftidunin.exe file in the Systems 32 directory then hit retry, it will work - trust me :-)
I've edited my instructions in the earlier post to say that you actually have to click in the ftdiunin.exe file, rather than just browsing to the System 32 directory.
markyeulett
Allocator, All - Bingo!! Many thanks for all of your help.
I have it working :-)  I tried to upgrade firmware but that did not work, but the application is working - should I be worried?
Is there an upgrade to 1.4 available yet?
Many thanks again for your support
Best Regards
Mark
What did the message say when you tried to upgrade the firmware?
1.4 is not ready yet, nearly there.
markyeulett
I attach the message - there is still a problem.  The box works on Network flights but is not populating any 'my flights from the aerial'.
Message says can't find file rb.dll
[attachment deleted by admin]
markyeulett
managed to resolve that - saw on your site that firmware file had to be in RB directory - however this does not solve problem - box is not working lights on front not flashing?
markyeulett
N early crying now - I have 1.0 running on other machine and since updating firmware the box is not working with that software either.  Is it not backward compatible - No service now?
I can't believe how frustrating this is - Administrator - Please advise what I can do here?
markyeulett
Robin
Many thanks you are a demon ...all working again!!
Mark
piper-pilot
#22
Hi Mark
Glad it is all Ok now! any more problems please feel free to give us a call.
What did you think of the antenna?
Chris @ ML&S
CHRIS @ ML&S
markyeulett
Many thanks - new aerial working great - 20/30% more flights!  Highest I had previously was 55-60 and I peaked at 80 this morning.
Wayne
Hi Mark, Piper Pilot
Just wondered, is the new antenna you have the same one that is going to be part of the 'special antenna kit' that has been mentioned ?
markyeulett
no I dont think so Piper .. its a High Gain Aerial that I bought from Chris @ ML&S see http://www.virtualradar.co.uk/
