3D NETWORK PROBLEM NEW PC.
Started by MW0CVW, March 27, 2010, 01:45:42 PM
MW0CVW
Hello,
Please can anyone help with this 3D airnav issue.
I have installed Airnav 3D on new PC and have the folowing problems now.
1.3D view works fine in my flights no problem,but when i go to network flights,
the blue,red or green ball is shown with the flight numbers but will not display the aircraft icon when i click the balloon.
any help would be much appreciated.
Paul MW0CVW EGGP/EGNR
rashers
hi paul im having the same problem no one seems the have the answer very anoying having paid so much for software regards keith
Quote from: MW0CVW on March 27, 2010, 01:45:42 PM
Hello,
With the 3D Preferences set to minimum, you will only see the 'balls'
Medium will show 2D aircraft in the 3D disply and Maximum will show the 3D aircraft models.
rashers
thanks for that any tips to stop google from stalling i put ex ram and new grapics card in not solving it regards keith
I would start by deselecting Network aircraft processing - untick the 'Process Hardware flights' box at the bottom of the Network list.  Then experiment with local MyFlights traffic and the settings in the 3D Preferences.  Try Min/Med/Max, try reducing the Default number of trail points to zero, increase the Hardware Detected 3D refresh rate from 10 to 20.
If your 3 D view in the Google Earth window is still struggling, then it's more likely to be your PC rather than the RB software.  I'm assuming you have a good broadband connection and the latest drivers for your graphics card?
Once you have a nice smooth display using local traffic only, then you can add Network traffic and experiment with those settings.  I've got an old (5 yrs?) PC and I'm fine with local traffic, but the PC struggles if I try to ren Network at Maximum to get the 3D models.
rashers
thanks allocater for your help will try this
MW0CVW
Allocater,Rashers
Thanks for the information,adjust my settings and now displays correctly even when using 3D Network view.
I have also increased my disk cash in Windows setting (system) which has improved performance.
now using 19 inch screen with 2.4ghz quad core machine 3gb of memory
once again thanks to everyone for their help and support.
PAUL MW0CVW EGGP/EGNR
