3D GOOGLE PLUG-IN
Started by MW0CVW, March 28, 2010, 05:09:01 PM
MW0CVW
Hello,
I now have 3D working,thanks to prompt replys from other users.
One thing i have noticed is the google plugin quite often stops working and
reports is needs to be downloaded or re-loaded.
Have i configured Airnav 3d correctly?
Any advise would be appreciated
Paul
MW0CVW EGGP/EGNR
jasper37
yep i get exactly the same results re the plugin plus the program locks in the 3D
mode regular...........do other 3D users experience this also?
my pc is a very up to date spec running windows 7 and was only purchased a few weeks ago
must say getting frustrated re all this
are other 3D users experiencing same?
thx for any comments re this
Jeremy
G4DOQ
QRZ.com
jasper37
Can support plz help  regarding this problem?
thx
We haven't too many reports like this. If its the google plugin which is failing its not our code so its hard for us to debug this but we are looking into it.
MW0CVW
Airnav,
I appreciate your comments and look forward to your findings.
Paul
MW0CVW
EGGP/EGNR
rashers
this is happening to me reguarly if i had my way i would never got 3d very dissapointing has anyone answers regards keith
rashers,
Your symptons indicate your machine is not fast enough to handle the 3D models.
All those using the 3D version if you experience slow downs or the google plugin stops responding go to 3D View -> 3D View Settings.
You then need to experiment with the best settings for you versus performance. You cannot for maximum settings and quick refresh times if your pc is slow.
MW0CVW
Airnav,
If i leave the software running in 3D mode for long periods of time,the aircraft icons vanish from the screen.
Once i restart the software and the update with the server has been completed,
everthing is back to normal.
This could be a completely seperate issue.
PAUL
MW0CVW  EGGP/EGNR
MW0CVW,
If the plugin doesn't crash, it may be you have power settings to turn of your RadarBox after a certain amount of inactivity. Check your USB hub power settings and make sure they don't have any power saving settings.
MW0CVW
Airnav,
Thanks for your suggestion and comments.
Already checked the Power save options and confirmed they where all disabled,
as per a previous topic on the forum some time ago.
Not the end of the world, but gets a pain having to re-load the google plug-in
due to it aborting.
Kind Regards
Paul MW0CVW
EGGP/EGNR
WET, COLD & SNOW  in (Wales)
Jeremy
Can't get it to load at all today. Plug in just crashes, 2d ok. Tried re-booting the whole prog but still the same.
J.
G4DOQ
QRZ.com
Jeremy
The plug-in will not re-load. Comes up with 'feature you are trying use is on a network resource that is unavailable' etc. I am not on a network! It tells me try again but I just go around in a loop.
HELP!
Hi powered computer and XP.
J.
G4DOQ
QRZ.com
Jeremy,
The 3D version needs to connect to the internet and authenticate with our website. Are you posting on the forum from the same machine?
Jeremy
yes. I think I got some RF into the box today. I have lost all the Alerts etc saved in the registry.
Internet is fine and box working OK in 2d and seeing Real-time network etc. Just will not load GE plug-in.
J.
G4DOQ
QRZ.com
