3D Aircraft icons problem
Started by MW0CVW, April 23, 2010, 11:44:58 AM
MW0CVW
Hello,
The Aircraft icons vanish when viewing the aircraft in 3D mode.
This only happens once the sofware has been running for a couple of hours.
Flight ID,Aircraft type,Mode-s can still be viewed on the screen no problem.
If you zoom out the aircraft outlines can be seen in blue,red or green.
Re-loading the Google plug-in, makes no difference at all.
Note:Hardware and network flights are set to maximum.
The only way i can resolve this issue is to re-start the software and it works fine for the next couple of hours.
Any thoughts or comments would be appreciated.
Kind Regards
Paul
MW0CVW EGGP/EGNR
