ARNB installation on Win 7 problem
Started by Deadcalm, April 24, 2010, 06:53:54 PM
Deadcalm
Just done a Windows 7 (32 bit) installation on my computer, and tried to install ANRB 3.13.  It went OK up to the time it required more station information from me, and froze, despite entering Lat, Long, etc.  Tried it several times with the same result.  Anyone else experienced this, and what may be a way around the problem, please?  Are there specific Win 7 32 bit drivers, or should the usual ones be OK?
DC
besty
Hi Deadcalm have you tried starting in demo and putting your details in then and restarting the program? not sure about windows 7 32 bit but I would think they're the same drivers.
Stuart
Deadcalm
Sorry, Stuart, not familiar with "demo".  All was OK with XP for a couple of years, but Win 7 a bit of a pain with installing legacy stuff at the moment.
DC
When the pop-up box comes up at program run (when you would enter your user name and password), one of the options in that box is 'demo' mode.
Deadcalm
OK, thanks - never noticed that before!  I've tried it, but having completed the preferences panel and "applied" and "Ok'd" the panel, nothing registers and the panel stays put.  From memory of my original installation, the Lat/long data is in degrees and decimals, isn't it?  Other than that, I can't see an obvious problem in what I'm inputting.
DC
besty
Deadcalm
Well, thanks chaps - I'm stumped, then!
DC
That's decimal degrees, like:
51.1235 -2.4567
With west (and south) being minus.
Deadcalm
Yup, as I suspected.  Any other ideas?  I take it, then, that the only alternative drivers would be for the 64 bit flavour of Win 7, and that the 32 bit drivers are the same as for XP?
DC
I haven't actually adopted Windows 7 yet, so I've reached the end of my gathered knowledge I'm afraid.  There are guys here running 7, so I guess that you will have to wait for one of them to advise.
Hi DC, I know this sounds a bit of a convoluted solution, by try loading v2.01 off CD, connect RB, and see if that allows you to input the required Home Station Data, if it does and runs OK, then try starting 3.13, and that should also be OK.  Go to Control Panel and remove 2.01.
Deadcalm,
Right click on the RadarBox icon and select run with admin rights. Then run RadarBox 2010 and it should work fine.
Deadcalm
Thanks Airnav and CoastGuardJohn.   Airnav, no, the problem still persists even when running as Administrator.  I'll try uninstalling and using John's suggestion.
I just can't get any further than the Preferences box - it won't go away (or accept any details)!!
DC
orkney
#13
hello
I have just been think it might be possible to directly edit the ainav registry with the lat long, however I noticed it was in a different format but I was able to write a converter to convert it from from decimal to airnav registry. you can download it here if you would like to try it
clicking on the link doesn't work so just copy and paste this into your address bar:
http://radarboxorkney.gofreeserve.com/AirNavRadarbox_files/ANRBLatLongconverter.zip
Andrew
Deadcalm
I've made SOME progress - after completely uninstalling, then reinstalling from the original CD (CoastGuardJohn's suggestion) I managed to get it to accept my location details, and then copied the v3.13 exe file back into the Airnav directory - but now no signals or aircraft.  I've checked the drivers are loaded, they are, and Win 7 says the Radarbox is working OK, but the Radarbox "Hardware: Checking box" is yellow, and the blue USB light on the unit is blank, whereas it flashes for a short time when the computer starts up. I'm going to persist, as I'm NOT going back to XP now - too much hassle...
DC
