Problem with tracking - it is tracking on PP
Started by QF1, April 26, 2010, 03:42:53 AM
QF1
I am trying to feed from near Singapore while on holiday, but receiving some aircraft, but mostly none are tracking in Air Nav, but they are showing on my PP feed.  Does any one have any suggestions at why AirNav is not showing the aircraft as tracking?
Mark
viking9
Mark,
Are they showing on the AirNav network?
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
mjleprix
I have a similar situation where I have been flights on Airnav to the west of me but if i switch over to Planeplotter (only trialled in the last few days) I can view them quite clearly .   As Planeplotter receives its info through the Radarbox, I would have thought it would be of great interest to all concerned and particularly yourselves at Airnav.
(There is no network traffic involved in this issue). It is all too easy to suggest it should be dealt with by PP:I always believed this Forum to be helpful, but of late I'm not too sure, as queries are being sidelined under the excuse 'its somebody else's problem'.
Generally I am as happy as Larry with my Radarbox but if there is an opportunity for improvements by getting feedback from others, then lets hear about it. Thats' what a forum is for and suppressing that feedback causes frustration and often the route to many of the embittered posts we tend to see these days.
mjleprix,
We have no issue if you posting saying, I am seeing this on PP and its not on RB. Thats fine as your discussing an issue related to RadarBox. PP has been mentioned 100s of times here like that.
If there is a post saying PP isn't working, how can can we get it working or issues like that, then they do not relate to RadarBox and they shouldn't be here. This is not a support site for PP and shouldn't be used as such.
A couple of things in Planeplotter can give the impression of it tracking flights that don't appear on the Radarbox display:
1. Timeout settings.   Try to match your timeout settings between Radarbox and Planeplotter.  If your timeout settings in Planeplotter are bigger than those in Radarbox, then obviously aircraft will appear in Planeplotter that have already timed out in Radarbox.
2. The "Predict Postions" setting.  If you tick this in Planeplotter, then even after aircraft have timed out in Radarbox, they will continue to move in Planeplotter.  This is not REAL movement, but predicted movement in Planeplotter.
During beta testing of port 30003, I tested Planeplotter with identical timeout settings, and "Predict Positions" turned off, and found no discrepancies.
mjleprix
Tarbat
I completely understand what you are saying about timeout settings and predict positions as I too have appreciated those implications, but for what its worth in my particular case aircraft tracking north or south between 50 -80 miles west of me are sometimes not being picked up at all and during my testing of planeplotter such missing tracks(aircraft) are on the map on planeplotter. Now I certainly do not have your very good technical understanding of related issues,but to me I wonder why this is the case. I totally accept that aircraft staying on track for longer or even being predicted to be in a certain location is down to the way planeplotter works. I actually find this helps me because sometimes I miss the first contact and wheras the aircraft might have gone off the map in Radarbox when I'm focusing on what is in the vicinity, I am reminded of its track if I flip over to planeplotter and in that way it enhances the set up overall for me.
But if we didn't discuss the availabilty of such add ons(perhaps i shouldn't have said that word) then we wouldnt be aware of their value to our community. Perhaps my wording or earlier missives wasn't quite appropriate but when time is short you just want to get the message across. I know there are people such as yourself on this forum who have mentioned Planeplotter and are fully conversant with their operation and if i had been able to access their personal Email address I wouln't have even raised the question on open forum.
Hope this explains what I was about.
Mike
mjleprix, are you running the latest version of Radarbox?  And what's your location?
mjleprix
Okay, that rules out the southern hemisphere missing data issue.   Are you sure you haven't got the Planeplotter network sharing turned on when you're seeing this?
mjleprix
Absolutely not, Tarbut, I am only running the 21 day trial during which time you are unable to share data.
Mike
Sorry Mike, I'm out of ideas.  For info, I use the following settings and see excellent correlation between the Radarbox and Planeplotter maps:
1. Radarbox Timeouts for MyFlights - 23/37
2. Planeplotter ModeS source - SBS1/RBv3tcp (very important)
3. Planeplotter "Omit Aircraft after" - 1.00 minute
4. Planeplotter "Predict Positions" unticked
5. Planeplotter sharing - Upload ONLY
mjleprix
Tarbat
I'll have to check the I/O settings on that Mode s source I'm sure mine was pointing at the RBs box a little lower down the list. I cannot get the flight routings to populate either. If you could pm on that set up if the answer is in the [email protected].
Once again you have been very helpful.
Thanks Mike
#13
If you're using any of the other Radarbox option in I/O, then that may give you problems, since some/all of the other settings expect a 5-minute delay.  As long as you're running v3 or later of Radarbox, then you MUST use the SBS1/RBv3 tcp I/O setting.
Flight routings do not get passed from Radarbox to Planeplotter on port 30003, only the FlightID gets passed.  To see flight routings in Planeplotter, you'll need to build a flight routes table for Planeplotter to use, or get hold of FD6 to automate flight routes in PP.
Quote from: tarbat on April 27, 2010, 02:10:54 PM
Or you can download a starter flight routes database compatible with PlanePlotter from the Files area on the Yahoo PP-Logs-and-Routes Group:  http://groups.yahoo.com/group/PP-logs-and-routes/files/
