New RB 3NM SE of EIDW
Started by Dec, February 23, 2008, 02:40:44 PM
Dec
mt007
Hi how are you?
Do you have RB?
Dec
Hi, yes just up and running this week with the RB, i'm 3 Nm from EIDW, and 1 NM south of the approach to RWY 28 at 800FT,
Welcome to the forum Dec
Enjoy your RadarBox and don't be afraid to ask questions :-)
mt007
Welcome.
And put screenshots, :):)
Regards.
Dec
Thanks mt007,
will put screenshots in due course,
Dub33
Hi Dec
Great to see another member in the Dublin area. I seen your screenshots and You're getting great coverage, especially north west of Dublin.
I'm 6.1 miles SW of the centre line of 10/28 EIDW.
I'm looking forward to enhanced coverage
Best regards
Dub33
Dec
Hi Dub33,
I guess we both have EIDW Very well covered, I just sold my SBS-1 so I'm in the process of getting a new antenna, I think i'll try get something a little special, as I was using an extended whip on the SBS-1 with a pre-amp and had excellent coverage.
Dec
Dub33
Hi Dec
I'm in the process of upgrading my antennae as well. I'm getting between 35 - 60 flights in "my flights", depending on the time of the day..
I had looked at the ML&S web site, however, AirNav mentioned they were in the process of rolling out a special antennae kit for the ANRB, so i decided to wait and see.
That was back in Jan.08, I'll give it a another week, and if no sign of it by 01/03/08, I intend reverting to ML&S. However, all suggestions are more than welcome.
Another member on thos forum, I think it was "Piper Pilot"suggested using a high Gain whip, without the pre-amp.
johnnyB
#9
Welcome Dec, its great to see a few more irish users!
QuoteI had looked at the ML&S web site, however, AirNav mentioned they were in the process of rolling out a special antennae kit for the ANRB, so i decided to wait and see.
I am in the same boat, i am waiting for the airnav aerial to increase my coverage. Im in Sligo in the northwest of Ireland and i get a lot of flights over head but because of the position of my aerial (on the gutter) i lose them when they head for the Atlantic.
Hopefully we wont have to long to wait for the aerial upgrade and V1.4
Dec
Hi Dub33,
I've found a few antenna on the net, might be worth a look, i'll post links later,
I have a discone its a few years old that itself might be worth a try if I change the coax and connector on it, get some new low loss for it.
Dec
Dec
Hi JohnnyB,
Thanks for the welcome,
Shame your loosing flights as they head for the atlantic,  I'm sure if a new antenna improves your situation we'll all be in for a feast as transatlantic flights come and go,
Kind regards
Dec
Dec
Hi guys,
here are some links to new antenna, seems to be a few on ebay, not sure if they would be an improvement or not, however i might just splash out and take a chance on one or another,
if i do i will report back with results.
http://www.haydon.info/37_antennas_scanner.htm
http://cgi.ebay.co.uk/AIRCRAFT-TRANSPONDER-ANTENNA-KINETIC-AVIONICS-SBS-1_W0QQitemZ370022769957QQcmdZViewItem
http://cgi.ebay.ie/ws/eBayISAPI.dll?ViewItem&Item=280198195818&Category=40979&_trksid=p3907.m29
Dub33
Cheers Dec
Much appreciated.
I noticed you're getting EIDW aircraft right down onto the runway and taxiways, excellent stuff. I was only getting it down to circa 320 ft.
Dec
Hi Dub33,
I have to admit that I find aircraft on the ground at EIDW was so much better when I was using the SBS-1, the amount of traffic was like rush hour on the M50, it was great, but now with the RB I reckon I could be getting less than 50% ground movements than before.
But I'm sure it has a lot to do with the antenna supplied with the RB.
I guess I'd better get my skates on with buying a new antenna.
kind regards
