Tools for RadarBox
Started by f6gsg, February 23, 2008, 09:09:27 PM
f6gsg
Hello,
It has been one moment since I try to exploit the data of the RadarBox,
either to follow in particular a plane, or to see the track of this plane.
Regrettably, for me, i must work to feed my family (and pay me toys as the RB) and thus
during the day, I cannot watch the RadarBox.
My idea is to put the RadarBox in recording mode and to exploit after
the file rbl.
I thus developed a program RBTools, allowing to exploit the file rbl
nnd to transform them to RE-EXPLOIT it withe the RadarBox or Google EARTH.
There are three functions on this program:
The first one, the cleaning allows to get back the file rbl and to clean it, it is has to delete the lines which have not data with longitude and latitude.(because no interest to observe them).
The seconds functions (FILTER) allows to filter the planes of this cleaned file, he allows to show the list of the planes of this recording
and to export them in a new file which will contain ONLY the concerned plane.
In more, for the fun, you can recorded it, in speed mode (FAST), the plane is going to move approximately 10 times as fast in the screen...
Some example:
http://www.lesaunier.com/rbt/FI_AF559FU_X10.rbl
http://www.lesaunier.com/rbt/FI_AF684ZA_X10.rbl
(South of France)
The principe is to reduce the time data on the record  .brl file, so the time is not
linear but it's funny !!!!
The third function (GPX CONVECTOR) allows to export a plane selected in a file size .gpx, which can be open with Google Earth, what allows to have long tracks or the sight of the plane on the real ground.
Long Trace
Short trace
On the airport
the file gpx:
http://www.lesaunier.com/rbt/GPX_AF556FN.gpx   (download it)
For all the file, the program automaticaly create new name with header (FL for filter, GPX for GPX and extension X0 for the fast mode).
i filter or gpx function, the number in the table with the name of flight is the number of record of this plane on the file, more is important more you have detail and long trace.
it's run well in flight identification mode,not so good in only mode-s detection. (problem with multiple identification)
You can download this program at the following address:
http://www.lesaunier.com/rbt/RBTools11.EXE
it's an auto extractible program.
i have more idea (as compressor function), but i'm waiting for the V1.4, if i want to make bridge with the SQL database.
I prepare a documentation (make long time), it's a freeware and I am not a "pro" of the programming,  has, there is certainely some bugs ... i'm waiting for your comment
(sorry for my bad english).
Good play
Patrick / F6GSG
Patrick,
Thanks for posting the RBTools program, I look forward to using this.  You link does not download as the exe part needs to be in capitals like:
http://www.lesaunier.com/rbt/RBTools.EXE
I have downloaded the file and will take a look.
Patrick,
All very good!
The only part I am having trouble with is the GPX Convector, with the error message below.
Erreur à la ligne 37 du traitement Clic sur BTN_ELLIPSE.
Vous avez appelé la fonction fLitLigne.
Vous avez demandé à manipuler le fichier n°-1 qui n'a pas été ouvert par fOuvre ou fCrée.
Informations techniques
Projet : RBTools
Dump de l'erreur du module <WD100STD.DLL> <10.00Bp>.
- Appel WL :
Traitement de <FLIGHT_GPX.BTN_ELLIPSE>, ligne <37>, thread <0>
Fonction <fLitLigne>, n° de syntaxe <0>
- Niveau : erreur fatale (EL_FATAL)
- Code erreur : 80022
- Code erreur WD55 : 0
- Pas de code d'erreur système
- Pas de message d'erreur système
- Que s'est-il passé ?
- Infos de debug :
Fonction (8,177)
- Infos attachées :
EIT_DATEHEURE : 23/02/2008 21:48:24
EIT_PILEWL :
Clic sur BTN_ELLIPSE (FLIGHT_GPX.BTN_ELLIPSE), ligne 37
Clic sur BTN_Bouton1 (MENUG.BTN_Bouton1), ligne 1
- Identifiant dans le .err : 1
f6gsg
i allocator,
thanks for the information, and i know why we have this messsage:
The cycle is this:
first cleaning (not compulsory but advised, the treatment is faster)
second time FILTER OR GPX, but if you try filter
and go after to GPX, the left table is not empty, but it's wrong
you MUST select a rbl file, make GO and after choose a flight
to convert to gpx file.
it's a bug, i must clean the left table at the windows opening
(it's the same table and the memory is'not empty).
good luck !!!
Patrick
Thanks Patrick, got it now!
Well done, nice utility and the first one to use the recorded files I think :-)
doro
f6gsg
hi,
i have just reload a new version 1.1
Correction of a minor bug (as see by allocator) and look change.
Good fun
Patrick/FGSG
Patrick, the new version is working well thanks.
An interesting track here from yesterday.  RYR341 into Liverpool EGGP form the south (the line on the left).  Made a single approach to Liverpool, then diverted to the SE (the line on the right).
Full size picture here - http://farm3.static.flickr.com/2260/2288265162_556624690f_o.jpg
Here you can see some of the approach - I lost the aircraft as it turned finals for Liverpool and RBTools joined the 2 lines.  I've inserted red dots where the aircraft would have flown but I didn't see - and I've made the RBTools extra line into a dashed line. Liverpool airport is marked by the red arrow.
Full size picture here - http://farm4.static.flickr.com/3065/2288265354_33cf3b1924_o.jpg
Patrick, you need to develop a way of showing the altitude on Google Earth :-)
f6gsg
hi allocator,
Altitude is on beta .... 1.2
next week.(with the compressor function)
Patrick/F6GSG
Dub33
Hi Patrick
Nice work, and Great to see that a forum member can create some useful new tools for ANRB users.
Thanks Dub33
Any idea what happened to this excellent tool.  I tried to download from www.lesaunier.com/rbt/RBTools11.EXE , but it's not there anymore.
waddington1
Me too I would like to use the program.
f6gsg
Hi friends ....
There is many reasons because it's not possible to download the RBT.
At first, with the new version of RB, i must change some functions
and adapt the recorder (because the recording function is a little different)
and in a same time i moved to Vista !!!! (pb with loalisation of data
recording)
But the most important reason is that i have changed of internet provider
since 2 weeks and i have not finish to translate all the data !!!!
So, i'm not in France actually (i'm at Miami - for my job of course) and in my return I am going to finish the work ... (in two weeks).
So thank you for the interest to this (small) product and sorry for
the inconveniences.
Patrick
