Author Topic: Windows 7 64bit install v3.13 - Any do's or dont's - Brand New laptop?  (Read 6698 times)
Tramline
Now that many people have begun using Windows 7 64bit with ANRB - I'm considering upgrading from Vista to Windows 7 but I wondered if users could advise if there are any special hints on the install - Any do's or dont's?
Many thanks,
« Last Edit: May 10, 2010, 07:48:14 AM by Tramline »
Located 2 miles South of LHR.
abrad41
Re: Windows 7 64bit install v3.13 - Lessons - Any do's or dont's
« Reply #1 on: May 09, 2010, 06:33:36 PM »
Hi Tramline
I use Windows 7 64bit, I had no problems with the install and the RB runs fine too under Windows 7. Only thing I would advise is to install away from the default install (Progam Files). I have mine installed at C:\AirNav RadarBox.
Hope this Helps
Andy
Tramline
« Reply #2 on: May 10, 2010, 07:47:34 AM »
Thanks for that Andy...I'll take note of that...sounds like a Vista requirement as well.
One more question.
I'm planning on buying a new laptop and I have the original ANRB V2.01 CD Rom disc but I downloaded V3.13 to upgrade on my old laptop - so with the new laptop can I just download V3.13 or do I need a code or do I load V2.01 via the CD ROM on the new laptop then download V3.13?
Can anyone advise please what I should do?
« Reply #3 on: May 10, 2010, 07:48:24 AM »
Just download Version 3.13 the full version and thats all you need.
Tramline
Thanks for that AirNav but surely anyone could then do that on any computer?  Isn't there a code I need to enter if its a totally new laptop? i.e No previous version of ANRB loaded?
You will need the account and password details.  Retreive these from your current PC in registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\Registration\Email
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\Registration\password
Tramline
Thanks Tarbat.....where do i type these codes or rather, assuming the old laptop has started up and I have the desktop page up and running....where exactly do I type these codes?   I'm sorry I'm a techno numpty!
orkney
  • Database Updater Moderator
    • orkney radarbox screenshot
Hello
run regedit.exe. then you can locate any registry entry and modify it.
Andrew
You will enter the account and password details when you first startup Radarbox on the new PC.
Tramline
Thank you for the help and support chaps!  I'll see how I get on!
