Author Topic: Directional Mode S antenna ?  (Read 20941 times)
« on: May 18, 2010, 10:38:36 PM »
One for the aerial gurus.
I'd like to run my SBS and/or RadarBox with a directional antenna so that the box predominantly picks up traffic in one direction - in my case to the east, which would cover LHR arrivals and departures.
Does anyone have any suggestions for either an off-the-shelf directional antenna or for how I could suitably screen my existing omnidirectional aerial to achieve the same result ?
MTIA
Dave
Cumulus
Re: Directional Mode S antenna ?
« Reply #1 on: May 19, 2010, 07:50:07 AM »
Hi Dave,
I am using a FLU-SR/Y13 from BAZ. Excellent construction with good performance.
http://www.amateur-radio-antenna.com/professionalantenna/aeronauticalantenna/index.php
Cheers,
Peter
« Reply #2 on: May 19, 2010, 08:39:39 AM »
This will probably do the job Dave - at least it's not too expensive.
When I was considering a new antenna myself a couple of months back, I seem to recall a bit of discussion about it on a couple of the other forums.
http://www.nevadaradio.co.uk/avionics/moonraker-high-gain-1090mhz-
« Reply #3 on: May 19, 2010, 09:42:00 AM »
Thanks, guys.
The other option I was thinking of, since I need directionality but not really any extra gain, was to use the existing aerial with a DIY screen to suppress signals from unwanted directions.
Any suggestions for a suitable design ?  I'm thinking a section of plastic guttering wrapped in tinfoil, but that's not very elegant :-)
« Reply #4 on: May 19, 2010, 09:54:56 AM »
Perhaps a bit OT, but if some bright spark out there could come up with a very basic, very simple and very cheap SMA switcher, it might prove a useful bit of kit for many of us.
(Two antennas feeding in to a switch which would allow manual selection of the preferred single feed to the RB)
Jeremy
  • Jeremy
« Reply #5 on: May 19, 2010, 10:32:03 AM »
I would have thought a small directional beam antenna would do the job for you especially as you want directivity rather than gain. 4 odd directors, a simple dipole and a reflector. I can't remember what the spacing is off hand but I can look it up. It doesn't need to be perfect as you are only receiving on it.
By the way - dustbin lids make good parabolic reflectors and would screen you present antennae nicely!
Coax switches are easily available at amateur radio outlets such as W&S.
J.
G4DOQ
QRZ.com
« Reply #6 on: May 19, 2010, 10:43:34 AM »
Love the dustbin lid idea !  :-)
Mike_Tassy
« Reply #8 on: May 19, 2010, 11:12:12 AM »
Dean
  • Plane photographer
« Reply #9 on: May 19, 2010, 06:07:27 PM »
Cumulus
Any chance of a screen grab of your polar patern using a yagi antenna?
Hi Dave,
Cheers,
Peter
Cumulus
« Reply #10 on: May 20, 2010, 08:18:57 AM »
Polar diagram available on BAZ website. I use the yagi when mobile for EGLL ground movements at a distance of 25nm. Gives a 30% increase in ground targets compared to an omni.
http://www.polarorbiter.co.uk/YagiMobile.jpg
Cheers,
Peter
iain5968
« Reply #11 on: May 23, 2010, 11:12:02 PM »
Sorry for the late reply, Moonraker now do a yagi for 1090mhz sells around the £50 mark.........
 RADAR-SKYSEARCHER 1090MHz DIRECTIONAL ANTENNA
Type: 1090MHz High Gain Directional Antenna
Frequency TX: 1090MHz
Frequency RX: 980-1200MHz
TX Gain 14.5 dB
Power: 50W Max
Impedance: 50 Ohm
Dimensions: 490 X 200 X 180mm
Mounting Masts up to 5.6cm (2")
Socket: SMA Female
Weight: 0.45Kg
This antenna is designed to be used for the increased reception of Radar Mode-S and ADS-B signals on 1090MHz. It is a brilliant directional antenna for AirNav Systems RadarBox and Kinetics SBS-1er Pocket Radar
Manufacturer: Moonraker
Model: 11-571
Price: £49.95
regards
iain 2M0VVS
« Reply #12 on: May 24, 2010, 06:41:18 AM »
Thanks for that - as it happens I currently have on of those on loan for evaluation (I'm not sure I'd describe it as a Yagi, though).
iain5968
« Reply #13 on: May 25, 2010, 05:01:24 PM »
Dave to many reflectors to be a "normal" aerial :)
hard to describe though !
iain 2m0vvs
Jeremy
  • Jeremy
« Reply #14 on: May 25, 2010, 06:24:25 PM »
Thats a parabolic reflector!
J.
G4DOQ
QRZ.com
