Advanced Filters
Started by John Racars, May 19, 2010, 11:10:24 AM
John Racars
Quote from: tarbat on May 24, 2010, 12:06:17 PM
Best to Auto Set QNH for your local airport:
Tarbat, thank you for the help! Done. Hope this helps.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
John Racars
Hi Tarbat & All,
I am running my RB with "Auto Set QNH" with Advanced Filters in use for a couple of hours now and it looks that my "advanced filters" problem is solved.
Tarbat, thank you again!
13 NM East of EHAM
ANRB:
Glad that's solved for you John.
Airnav, I guess there's a bug somewhere in Radarbox that can't cope with negative altitudes.
Quote from: tarbat on May 24, 2010, 02:54:36 PMnegative altitudes.
That would be the Dead Sea area.............?
John Racars
Quote from: CoastGuardJon on May 24, 2010, 08:53:52 PM
Hi All,
For your information: EHAM is situated BELOW sea level. Maybe that could be the reason of negative altitudes with me....?
13 NM East of EHAM
ANRB:
And even airports above sea level will show aircraft at negative altitudes just before touchdown on high pressure days, assuming no correction for QNH.
malc41
Dont they use QFE any more?
15 Miles East of EGNJ
British military airfields do use QFE.  Most civil commercial airports use QNH.  Of course, there are exceptions.
