Author Topic: Advanced Filters  (Read 9079 times)
John Racars
Advanced Filters
« on: May 19, 2010, 11:10:24 AM »
Hi All,
Sometimes of the day I want to see flights between 500 and 40.000 ft only.
So I do as follows: (Map view mode)
1. Click Filters
2. Click Advanced Filters
3. Base FT fill in 500
4. Top FT fill in 40000
5. Click Altitude
6. Click Close
After doing this the RB works for a short while normal but after some minutes the program hangs and or the maps does not coming back after change to the www or some other program on the background.
Is this an already known problem? If not what should be done to let the filter working without causing any problems?
Thank you for any help in advance!
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
John Racars
Re: Advanced Filters
« Reply #1 on: May 19, 2010, 04:20:21 PM »
Sorry if I made verry strange problem or question. You should ask if I am not clear? There was NO reaction from support so, what do you think? Was I clear OR not? I am not a little child what is asking something and I did not Highscool English. So please excuse me if I was not clear in questioning.
13 NM East of EHAM
ANRB:
DaveG
« Reply #2 on: May 19, 2010, 04:23:28 PM »
Sorry John,  Just tried your Advanced Filter (Different Alts) and all seems to be working okay, so far.  Will leave running for a bit longer.
Cornwall, UK
John Racars
« Reply #3 on: May 19, 2010, 04:30:43 PM »
No answer from support.
When I am asking "some time" when I see a problem it must be verry difficult.
I will be patient.
13 NM East of EHAM
ANRB:
« Reply #4 on: May 19, 2010, 04:55:12 PM »
John,
Firstly please read:
http://www.airnavsystems.com/forum/index.php?topic=607.msg25029#msg25029
Now regarding your issue, we haven't had any issues of this so far. If others see it please both on this thread.
DaveG
« Reply #5 on: May 19, 2010, 05:22:29 PM »
Okay had it running on Advanced Filter now for 1hr and all okay.
Cornwall, UK
dl1812
« Reply #6 on: May 19, 2010, 05:40:35 PM »
For what it's worth, I run in advanced mode all day, as I work close to Heathrow and obviously need to keep the "clutter" down.
So far I've had no problems.
I know that doesn't help John, but at least we know that it does work.
Running Windows XP / 3.13 Software
Dave
John Racars
« Reply #7 on: May 19, 2010, 05:49:23 PM »
Hi Dave, thank you. What I am running is something others then you. Maybe there is a problem? Look in my frofile what version I use...
In the past, when I was using the version like you use now I did not have problems I just talking  about...
« Last Edit: May 19, 2010, 07:03:03 PM by John Racars »
13 NM East of EHAM
ANRB:
« Reply #8 on: May 20, 2010, 07:26:54 AM »
John, I applied the same advance filter as you, left it for an hour, and I don't see the problem you're seeing - no lockup, etc.
John Racars
« Reply #9 on: May 20, 2010, 01:03:35 PM »
OK. Thank you all for your reactions! Highly appreciated.
Must be an individual problem so it looks.
There is an other strange phenomenon:
all landed a/c at EHAM heap up there. So from time to time I stop processing to clean up my screen....
This is not the "normal way" of using the programm I think but it looks I have a strange version.
13 NM East of EHAM
ANRB:
« Reply #10 on: May 20, 2010, 01:48:10 PM »
Do any of the aircraft appear with negative altitudes?
John Racars
« Reply #11 on: May 20, 2010, 03:43:49 PM »
Hi Support,
verry good. It does. All altidudes are negative.
13 NM East of EHAM
ANRB:
« Reply #12 on: May 23, 2010, 09:08:02 PM »
maybe you have the wrong QNH set?
John Racars
« Reply #13 on: May 24, 2010, 11:47:12 AM »
Hi Tarbat,
I never changed this setting so it is still 985. What do you think about this setting?
13 NM East of EHAM
ANRB:
« Reply #14 on: May 24, 2010, 12:06:17 PM »
Best to Auto Set QNH for your local airport:
