Author Topic: 3D Demo  (Read 2516 times)
alavana
3D Demo
« on: May 21, 2010, 11:56:17 AM »
I`ve watched the video on youtube http://www.youtube.com/watch?v=ZDG5pdvlUWE by "The Development Team" - (AirNav RadarBox 3D) and it clearly shows aircraft at altitude on display.
The Demo mode gives me views of coloured pins, whereby on clicking them, they open up a tab of the aircraft.
Can someone confirm that the real 3D software gives you the actual view of aircraft?
I`m viewing this on a 30" Dell PC Monitor with a native resolution of2560 x 1600 and I`m not sure if I`m meant to be seeing aircraft in the Demo mode or coloured pins as I have no idea what the limitations placed on the DEMO version are?
« Last Edit: May 21, 2010, 01:37:21 PM by alavana »
Re: 3D Demo
« Reply #1 on: May 21, 2010, 01:41:00 PM »
You can set to view pins, or the models of the aircraft. Its in 3D settings where you can choose the settings for your 3D display.
The reason for this, is that the better visuals the faster PC you need. This so you can set your own setting for the best performance and visuals your PC can achieve.
alavana
Re: 3D Demo
« Reply #2 on: May 21, 2010, 01:59:04 PM »
Thanks for the information.
« Last Edit: May 21, 2010, 02:07:37 PM by alavana »
