Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
Chris11
knight01 - Just a tip - sometimes when you click on the item it populates immediately and sometimes it will tale a while - 10 or so seconds - so click the item and wait a bit. Also, if you are not sorting the screen on Mode S code then it will "disappear" when it is populated as it will get sorted as soon as it is populated.
andrewarles
A/c not populating
38289A / F-WWYG Airbus test registration
398A61 / F-HCTB / DA-42 / 42-299 / ETAT / DIRECTION GENERALE DE L'AVIATION CIVILE / SEFA
4B1F27 / HB-LUT / P180 / 1201 / Greenwings SA
A072B0 / N128PA / P180 / 1209 / PIAGGIO AMERICA INC
AE19DD / A-10A shown on AF.org and GAS as 81-0988 but with Callsign 81000962 ?
A/c name, cn and owner missing
390211 / F-GAQR / C182Q / 0053 / AERO CLUB DU VAR
384A24 / F-BSRE / C414 / 4140156 / R' PARTNERS
A75D1B / N57384 / Mooney M20J / 24-1447 / HUNZIKER ROGER F
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
Thanks Andrew, all added or amended. BTW the A10 is 81-0988 c/n 683.
Chris11
#798
780476 B-5381 Boeing 737-87L B738 35528 Shenzhen Airlines
Keep picking up AAFC48 with Flight ID N807EF - but there is no such aircraft on the US register
Thanks for the Shenzhen, Chris.
Unfortunately there are a lot of miss codes operating in the US.  That code comes out as N807EF and as you state, there is no such aircraft.  We may get an answer someday if someone gets a visual contact.
Quote from: Runway 31 on September 29, 2010, 11:43:04 AMUnfortunately there are a lot of miss codes operating in the US.  That code comes out as N807EF and as you state, there is no such aircraft.  We may get an answer someday if someone gets a visual contact.
If it helps to narrow it down, my network capture log has it climbing out of Portland, Maine around 1220UTC yesterday.
Chris11
It was just interesting that the pilot had entered that registration into the transponder as it showed up as the flight ID
Maybe an automatic thing taken from the hex code being used.
Chris11
C06A12 C-GOEJ Boeing 737-7BD B737 33920/1753 New Air & Tours
Cheers Chris I noted it abeam the Wash heading North and had just asked the mode-S forum.
Chris11
 A71D55 N558C Stinson  108-3 S108 c/n108-3558   MEIGGS CINDY
anorak
Dave. Exmoor, North Devon.
4B185E refers to HB-JFY,  Bombardier BD-700-1A10 Global Express , c/n 9347, Rolex SA.
