Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
GrizzFlyer
"ms" – ADFEB8
"ar" – 98-0002
"at" – B752
"co" – US Air Force
Flight ID: AF2
Incorrectly lists airline as Air France, probably because of its AF2 flight designation.  Its overhead here now.
Daryll in NW Ohio
Hi Daryll,
As you state its the AF2 which is causing the problem nothing the updaters can do, over to you Airnav
#887
Thanks Knight01, all added.
382A5A F-WWYT A330 test registration.  Will become HZ-AQF eventually.
40298F G-BNUT Ce152 c/n 15279458, Stapleford Flying Club
43C8BB ZA681 Chinook, c/n M.7002,  UK - Air Force
Chris11
For the aircraft that there was missing information all I had was ms,ar,at - It could be a problem with slow populating. I will watch over the next whil - also leave the cursor on the affected aircraft for a while. I will report back if there is still an issue.
andrewarles
A/c not populating
300338 / I-MFAB / Hawker 900XP / HA-0074 / Skybridge Airops
3815BA / F-WWBE Airbus A.320 Test registration
385BBB / F-CJVV / SF 25 C / 44720 / FEDERATION FRANCAISE DE VOL A VOILE / FFVV (Callsign FCJVV)
386A3B / F-PERK / JODEL D 113 V / 196 / AERO CLUB DU HAUT COMTAT ET DE LA REGION (Callsign FPERK)
396531 / F-GZJR / Falcon 2000 / 191 / Dassault Aviation SA
3988AB / F-HCFL / PA 34-220 T / 3449273 / SUD AIR AIXOISE DE LOCATION SARL (Callsign FHCFL)
3DDDD7 / D-HEGL (Callsign BPO408)
C04BF3 Canadian a/c at FL410
A/c name, cn and owner missing
385633 / F-BVRT / BE58 / TH-488 / SARL BRIMB AILES
3D37EA / D-ETKS / C82R
A4D680 / N4100H / M20J / 24-1029 / C R AIRE SERVICE INC
AE2209 populated as 37469, should be 08-8602
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
Thanks Andrew, appreciated as always.
All added with the exception of C04BF3 which comes out as C-GCTU which is showing as a Falconar F-12 which will struggle to FL410.  May have been re-registered so I will keep an eye out for the change details.
The C30J has been amended.
Chris11
C-GCTU is a Jodel which will have even more trouble than a Falconair getting to FL410
Chris11
02007A and 4054A8 AC and CN fields swapped
ACW367
#893
Quote from: Runway 31 on October 07, 2010, 10:26:15 AM
Chris, I may have had something similar there.  I noted 780477, B-5383 which was all the information in my own database.  On checking the Airnav database everything is there as it should be.  I presume that the first time I picked it up the hex and registration were the only data downloaded as that is all that was on the Airnav database.
Now that we since updated the Airnav database with the remaining data, because there was data on my own database, something in the system prevents the remaining data being auto-populated probably to prevent your own data being over written, its either all or nothing, therefore a manual update will be required until a new navdata file is released.
Thats my theory anyway.
Edit 13:38 just picked up YR-BAC on the network and everything is there that should be.
If you have a photo on your C/.......Airnav/data/photo    local folder it will block further updates from the server.  Until the big bug is fixed we are not advocating users to delete too many stored pictures.  However, if you suspect details have changed, delete the individual picture on your C drive and new details will populate when you next recieve the aircraft.  For example I have changed all Continental jets in the DB to 'United Airlines / Continental Airlines'.  In order to get the 777s that I regularly pick up to change on my local radarbox, I first had to go to the photo folder and delete the relevant photos of them.
Chris, everything is in the correct order in the database for those 2 aircraft.  The time stamp shows they were updated in June.
Chris11
Just shows how important a datestamp field for aircraft is. :(
andrewarles
Evening Alan,
A/c not populating
38031A / F-WWKP Airbus A.330 Test registration
380DFA / F-WWBH Airbus A.320 Test registration
38181A / F-WWER ATR Test registration
383D1A / F-WWRQ SOCATA Test registration
3850BB / F-PNJL / LANCAIR LCT-30 / 01 / CHRISTOPHE TOSCAS
38739B / F-PUSS / DYN'AERO MCR-4S 2002 / 99 / DYN'AERO SA (Callsign FPUSS)
392651 / F-GJSR / EC 135 T2 / 292 / LIXXBAIL SA (Callsign FGJSR)
3C489A / D-ABDZ / A-320-214 / 4033 / Air Berlin
3C6D94 / D-AOLT / SAAB 2000 / 2000-037
3D2DD0 / D-EPPG
405D0B / G-RAEF / SCHEMPP-HIRTH KG SHK-1 / 39 / RICHARD ANTONY EARNSHAW-FRETWELL
45B890 / OY-NDP / 525A CitationJet CJ2+ / 525A0372 / Damson A/S
500009 / T7-PAC / PAC 750XL / 135
A97659 / N709DS / BD-700-1A10 Global Express / 9278 / CB AIR LLC
3D159E / D-EGLA
3D1432 / D-EFXA
A94DB6 / N699SA / PC-6/B2-H2 / 669 / AIRCRAFT GUARANTY TITLE & TRUST LLC TRUSTEE
Andrew
Arles, France.
Chris11
#897
That's it - blank or partially completed entries do not refresh if there is a picture :(
Quote from: ACW367 on October 07, 2010, 05:14:39 PM
Morning Andrew, many thanks again.
Couple worth mentioning.
3C489A D-ABDZ became HB-IOR for Belair / Air Berlin and I cannot find any information on it changing back, will look out for it.
3C6D94 is allocated to D-AKLT not D-AOLT which should be 3C7D94 so there appears to be a misscode at work.
I cannot find anything on D-D-EFPG or D-EFXA so I will hold them just now.
D-EGLA and is a Piper PA28-161 Warrior III c/n 2842251.
orkney
hello
D-EFXA is a XtremeAir Sbach 342 prototype still owned by XtremeAir.
Andrew
