3D Aircraft Icon problem.
Started by MW0CVW, May 31, 2010, 07:59:57 PM
MW0CVW
Dear All,
I have re-installed Airnav 3D on my new I7 Core Desktop with 6GB of memory
everything works fine for several hours no problems.
I then get the Aircraft Icon appear with a RED (X) in 3D mode for some reason.
If i re-start the software it runs as normal.
Paul w.
EGNR/EGGP
Whats your 3D setup, are you using maximum with all the settings on?
MW0CVW
Airnav,
All the settings in the 3D setup screen are set to maximum,
Hardware (max)
network-flights (max)
3d view (flight ID) (Aircraft type) (Altitude) (Destination)
update rates set 5 & 25 Seconds
PC Intel I7 2.8Ghz with 6gb of Memory 1GB graphics card
Paul w.
