Author Topic: Can the ModeSCountry Source Info Be Modified?  (Read 3803 times)
54901 - Jim
    • N9JHB.com
« on: June 06, 2010, 07:40:14 PM »
Is there a way of modifying the ModeSCountry data that is used to populate the MyLog tables?
If so, how?
Thanks!
Jim
KOSH - Oshkosh, Wisconsin USA
    • Rod's RadarBox Downloads
Re: Can the ModeSCountry Source Info Be Modified?
« Reply #1 on: June 06, 2010, 07:46:47 PM »
Hi Jim
File D008.DAT is the one that contains the country data/Mode-S codes tie-ups - hope you're good at binary!
I strongly suggest you back it up before playing!
There's a bit of a tutorial in the reference manual.
Good luck!
54901 - Jim
    • N9JHB.com
« Reply #2 on: June 07, 2010, 01:52:38 AM »
Thanks, Rod!  That sounds like a Monday project.  I'll check it out.
Jim
