Author Topic: My Radarbox has just stopped working.  (Read 8780 times)
CHILL51
« on: June 09, 2010, 05:47:34 PM »
My radarbox has stopped working. I have the power light on but the usb light flashes now and again but nothing from the signal light.
I have version 3.13. The usb light seems to flash once a second ive rebooted several times but no good any ideas ???????
Mike
Southwest
Re: My Radarbox has just stopped working.
« Reply #1 on: June 09, 2010, 05:52:27 PM »
Try re-loading the software.
CHILL51
« Reply #2 on: June 09, 2010, 05:57:14 PM »
yep done that aswell and still no good.
Thanks for the quick reply.
Mike
bearcat
« Reply #3 on: June 09, 2010, 06:31:16 PM »
Is your antenna connected ok? If you are using the standard twig have a look to see if the centre pin is showing, sometimes it would work it's way into the cable causing a bad or no connection,
CHILL51
« Reply #4 on: June 09, 2010, 07:14:14 PM »
Yeah ive checked the antenna connections i use an external antenna and everything was working fine until today. Im stumped !!!!! I have no idea whats wrong with it.
Mike
abrad41
« Reply #5 on: June 09, 2010, 07:25:26 PM »
You could try changing the USB lead
CHILL51
« Reply #6 on: June 09, 2010, 07:48:52 PM »
I was thinking maybe it might be the usb cable its worth a try. I will get one tomorrow and see if it works.
Mike
Southwest
« Reply #7 on: June 09, 2010, 07:48:59 PM »
The USB lead is a known problem.
CHILL51
« Reply #8 on: June 09, 2010, 07:54:03 PM »
Ah right thanks for that southwest. Fingers crossed it will do the trick as i can,t really think of anything else.
Mike
« Reply #9 on: June 09, 2010, 08:14:40 PM »
If that doesn't work, contact us and we will give you details on returning it.
CHILL51
« Reply #10 on: June 09, 2010, 08:50:19 PM »
Ok will do thanks
Mike
CHILL51
« Reply #11 on: June 10, 2010, 05:08:40 PM »
Well i changed the usb and still no good so i guess its time to send it off.
Mike
rashers
« Reply #12 on: June 10, 2010, 09:23:00 PM »
mike im having same problem network is showing yellow hardware showing red when i plug in usb cable it comes up usb devise not regonised can anyone solve this problem regards keith
« Reply #13 on: June 10, 2010, 09:43:23 PM »
rashers,
You need to install the drivers. Have a look at
http://www.airnavsystems.com/RadarBox/help/hardware_connection.htm
puddy
    • Puddy's Homepage
« Reply #14 on: June 11, 2010, 12:40:33 AM »
I have the same problem this morning
A pattern is emerging
Puddy
