Author Topic: NA Flight status  (Read 4388 times)
Chris11
NA Flight status
« on: June 16, 2010, 06:11:37 PM »
I sort my flights by distance. I always have a batch of flights at the top with a flight status of NA. Why do these not timeout and disappear?
I understand that this has been discussed before but a search that includes NA and flight status does not really work :)
Re: NA Flight status
« Reply #1 on: June 17, 2010, 11:45:55 AM »
Are these network flights or local hardware flights?
Chris11
« Reply #2 on: June 17, 2010, 01:10:18 PM »
Network flights. The local flights time out and disappear as expected.
« Reply #3 on: June 17, 2010, 02:38:56 PM »
Okay.   Discussed during beta testing at http://www.airnavsystems.com/forum/index.php?topic=3058.0
Previous replies for those without access to the beta forum:
NA means not available, flights which status is unknown. You will see lots of these flights on ground.
We will explain what happens: with the new network flight routines to avoid flights being concentrated at runway ends time-outed we had to introduce several time-out routines. These cause that some NW flights change to a different status. There is nothing we can do about the... unless change the flight status routine so it returns a different Status, not NA but...?
Maybe rename NA to TimedOut?  And ensure that these time-out aircraft still display their last known altitude in the aircraft list.
Corrected. NA flights will not be shown on the Network grid.
Chris11
« Reply #4 on: June 17, 2010, 09:08:25 PM »
Thanks tarbat
I don't have access to those topics but I assume it is normal to have the NA's
« Reply #5 on: June 17, 2010, 09:37:02 PM »
It's normal to have NA's.  Maybe Airnav can explain what NA really means, they're a real nuisance when you sort by Distance as well.
« Last Edit: June 17, 2010, 09:40:04 PM by tarbat »
