Author Topic: Airnav wont boot up with Win7  (Read 23490 times)
shytott
« on: July 03, 2010, 09:16:30 AM »
Ive just swapped from XP to Win7 (64bit), and Airnav wont move beyond the the startup screen - ie where you input username/password.  It just hangs and the only way to clear it is by the Task Manager.
Probably something basic but.............!    Any ideas?
Many Thanks
Northern Watch
Re: Airnav wont boot up with Win7
« Reply #1 on: July 03, 2010, 10:17:30 AM »
Hi shytott
Not that I am computer literate but I have been reading up on using ANRB with Win 7 and from other treads it could be a virtual store problem - did you install to the default directory in Program Files or into a separate folder as recommended in this forum. Type Windows 7 in the search box and it should give you various treads on the subject.
Rgds
Rgds
bearcat
« Reply #2 on: July 03, 2010, 11:16:22 AM »
Try starting it up in demo mode and enter your detaila then give it anothr go
shytott
« Reply #3 on: July 03, 2010, 11:46:21 AM »
Thanks Guys
Northerwatch,
yup, its in the Programfiles (x86) directory along with all my other apps
Bearcat,
It wont even start the demo!
shytott
« Reply #4 on: July 03, 2010, 12:02:20 PM »
Ive just installed the latest drivers and that had no effect.  Is there some sort of security issue with Airnav and Win7? , firewalls etc?  (this is Airnav 2007 - does that make a difference?
bearcat
« Reply #5 on: July 03, 2010, 12:23:52 PM »
I run it an a netboook with Win 7 (32bit) and no problems, but it is installed in its own directory on C drive. You could try right clicking the icon on staring Rbox and ruuning as Administrator.
Bearcat
« Reply #6 on: July 03, 2010, 12:49:50 PM »
Yes, hence the advice to install somewhere other than Program Files.  Best to install somewhere like C:\Airnav Systems\Radarbox
shytott
« Reply #7 on: July 03, 2010, 02:41:48 PM »
OK, sorry guys, I misread the advice.
I have just uninstalled Airnav,  then reinstalled it into the C/:.  Now the program does boot up, but its not receiving data from my antenna or internet.
Are there any speacial drivers I need to run Airnav 2007 on Win7 64bit?
« Reply #8 on: July 03, 2010, 03:12:20 PM »
Probably best to download the latest 64-bit drivers from the support page - http://www.airnavsystems.com/RadarBox/support.html
Scroll down to "Latest Drivers".
shytott
« Reply #9 on: July 03, 2010, 03:19:43 PM »
Hi Tarbet
Yup, Ive done that but it has no effect.
Whats happening now is, if I reinstall from scratch, click the desktop icon, it boots the program up to the logon window with teh username and password preinstalled and it will progress into the program but will not receive local or internet  data.   If i then close it down and try to relaunch it, all I get is the logon window, which is now not pre filled in and after populating teh usnername and password, it just hangs.  Even the demo will not work.  Yet, if i switch to my old XP machine,  everythings perfect.!!
« Reply #10 on: July 03, 2010, 03:36:17 PM »
Just noticed that you say you're running Radarbox 2007.  Probably best to download and use the latest version v3.13.
shytott
« Reply #11 on: July 03, 2010, 03:41:53 PM »
Well yes, I had wondered about that,  but isnt the latest version, the 3D version, and will that work with my older box?
« Reply #12 on: July 03, 2010, 03:48:37 PM »
v3.13 will work with any Radarbox.
Probably best to uninstall Radarbox, get the v3.13 installation zip, and then install that to C:\Airnav Systems\
shytott
« Reply #13 on: July 03, 2010, 03:53:25 PM »
Ok,  here goes..................
shytott
« Reply #14 on: July 03, 2010, 05:21:39 PM »
Nope, v 4.03 downloaded and it boots up, but still not receiving local or internet data.
