Author Topic: Multiple flight ID problem  (Read 5069 times)
airdata
    • Airdata
« on: July 29, 2010, 10:06:28 PM »
Greetings.  Not sure if anyone else has this problem.  In Auckland we don't have much traffic (26 at the most at any one time).  I note that often the same flight ID is listed with 2 or sometimes 3 different aircraft.  In most cases the hex code is similar but sometimes it is the 4th letter of the hex code that is different.  See the screenshot with 2 instances.  This happens several times each and every day.  It also makes no difference whether the my flights list is sorted or not.  Any suggestions to get rid of this problem?  Or is it a software bug?
Under the flight path, 5NM from runway 23L threshold at Auckland (NZAA), New Zealand.
Re: Multiple flight ID problem
« Reply #1 on: July 29, 2010, 10:10:24 PM »
The Hex Code Confusion bug is well-known and was first reported over a year ago.
No fix as yet.
pjm
  • RadarBox Beta Testers
« Reply #2 on: July 29, 2010, 10:35:34 PM »
or maybe you have multiple aircraft flying the same flight route.
I believe ANZ417 is Auckland (AKL) to Wellington (WLG)
and ANZ135 is Auckland (AKL) to Brisbane (BNE)
« Reply #3 on: July 29, 2010, 10:52:37 PM »
There is no way you could have two aircraft airborne simultaneously using both the same callsign and the same squawk.
« Reply #4 on: July 30, 2010, 07:11:15 AM »
And according to the bug tracking system, Airnav believe this occurs mainly in high message areas, whereas I don't think Auckland can be considered a high message area.
http://www.airnavsystems.com/bugs/index.php?do=details&task_id=16
« Reply #5 on: July 30, 2010, 08:51:56 AM »
I'd have to agree that the entry on the bug list doesn't seem to demonstrate a full understanding of the nature of the problem or (IMHO) the urgency of a fix:
Severity High
Priority High
Assigned To No-one
Due in Version Undecided
Due Date Undecided
« Reply #6 on: July 30, 2010, 10:01:40 AM »
Don't worry about those last 3 fields Dave, those details are kept private.
QF1
« Reply #7 on: August 09, 2010, 03:07:15 AM »
Hi there
Noticed this problem myself for the first time yesterday.  A (mode-S only) REX flight and a Virgin Blue flight on approach to Sydney, both showed with the same Virgin Blue flight number.  This only occurred on my RadarBox.
Mark
