Trail Line ...more long !!!!
Started by davis, March 06, 2008, 10:35:06 AM
davis
What should I do to lengthen the trail Line? In (second to remove trail line) from 200 to 900 or more 'does not change anything and always the same length......
The parameters change from 1 to 150 ..after is simile..I want a long track ( if is possible )
TNX  Gianni
Its not possible at the moment, as under lots of traffic and network it will put a lot of strain on a normal computer.
We may add this in future versions. Sorry about that.
davis
Quote from: AirNav Support on March 06, 2008, 11:53:12 AM
Ok .. It is not very important. Which is the optimal number that needs to  put in
(second to remove trail line) For the most track 'long ????????
TNX Gianni
marcdeklerk
Airnav.. how about this in V1.6?? thanks!
ENKB
On my wish list is an function that saves all trail lines during one day.  Then when you come home from work you can relate the information to the condense trails spotted during the day.
ChrisGR
Any advice on this question is welcoming.
A example here.
I have the Trail Lines to 100 sec.
This is good time for me to watch the routes.
Now i have also the Timeout for My flights box option to both 5 seconds.
And this because I think does not exist any reason to remains in my screen a plane since it is out of my reception range.
The question is how to i make this Trail line to disappear just in time when the airplane disappeared also after this 5 sec?
Thank you for reading.
