RadarBox 2008 Log File
Started by lennox2604, March 06, 2008, 09:16:09 PM
lennox2604
Just downloaded 2008
And it is GOOD
My onl very very small moan is that the Flight number is not includedin daily log .
Does anybody know a SQL set of commands to extract the information from the SQL database as I now very little of programming
Thanks AIRNAV
Any chance of a HFDL programme after Ship tracker
Jim C
#1
Quote from: lennox2604 on March 06, 2008, 09:16:09 PM
SELECT
  Flights.ModeS,
  Flights.Registration,
  Flights.Callsign,
  Flights.Route,
  Flights.StartTime,
  Flights.EndTime,
  Flights.Session,
  Flights.MsgCount
FROM
Flights
ORDER BY
SQL generated using SQLite Maestro
And this retrieves almost everything from MyLog.db3:
SELECT DISTINCT
  Aircraft.ModeS,
  Aircraft.Registration,
  Aircraft.AircraftTypeSmall,
  Aircraft.AircraftTypeLong,
  Aircraft.Airline,
  Aircraft.ModeSCountry,
  Aircraft.Comment,
  Aircraft.FirstTime,
  Aircraft.LastTime,
  Flights.Callsign,
  Flights.Route,
  Flights.StartTime,
  Flights.EndTime,
  Flights.MsgCount,
  Sessions.ID,
  Sessions.Location,
  Sessions.StartTime,
  Sessions.EndTime,
  Sessions.MsgCount
FROM
Sessions
LEFT OUTER JOIN Flights ON (Sessions.ID=Flights.Session)
LEFT OUTER JOIN Aircraft ON (Flights.ModeS=Aircraft.ModeS)
ORDER BY
  Flights.Callsign,
  Sessions.ID
lennox2604
Tarbat
Many thanks for that script
I know we have just started but how do you specify a date to isolate any day
Jim C
#3
Quote from: lennox2604 on March 06, 2008, 10:06:32 PM
WHERE
  (Flights.StartTime >= "2008/03/06 00:00:00") AND
  (Flights.EndTime < "2008/03/07 00:00:00")
will give you all flights on 6th March 2008.
BTW, I know almost nothing about SQL, but using SQLite Maestro lets you create SQL using the visual query builder.
lennox2604
Tarbat
Jim C
