Author Topic: Improved Routing Information  (Read 261061 times)
Re: Improved Routing Information
« Reply #315 on: October 02, 2010, 10:05:25 AM »
What format for the files, and where do we send them?  I can produce a file of daily Inverness arrivals/departures.  Thanks.
FLIGHT_ID,ORIG,DEST,DATE,TIME
BCS8491,,EGNX,"1/10/2010",2320
Header line is optional, time is assumed to be ATA/ATD at your local airport, in local time.
Either post the CSV file here as an attachment, or email direct to me, I'll PM you with the address.
viking9
    • Aircraft Photography
« Reply #316 on: October 02, 2010, 10:17:53 AM »
Flightinair - that's not Thick Mick again is it. He's had more nome-de-plumes than I've had hot dinners. :o)
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Chris11
« Reply #317 on: October 02, 2010, 10:24:37 AM »
Has anyone got a file with the IATA and ICAO codes for airfields
« Reply #318 on: October 02, 2010, 10:34:15 AM »
FlightDisplay comes with a CSV file containing over 8000 airfields, with ICAO and IATA codes and also latitudes/longitudes.
You don't need to install the program, simply extract the CSV from the ZIP.
http://sites.google.com/site/0flightdisplay/homepage
flightinair
« Reply #319 on: October 02, 2010, 10:36:19 AM »
yes someone told me about you, they call you  DADS ARMY.
 you got the wrong chap buddy.
spanman
« Reply #320 on: October 02, 2010, 10:51:59 AM »
Flybe weekend routes
Lets get back to what we love the most. Find attached the weekend alpha numeric routes for Flybe this Saturdat.Hopefully Tarbat will convert to a .csv file for us?
                        Mark
Flybe Crew on the Dash 8 Q400  Embraer 175
and Embraer 195
« Reply #321 on: October 02, 2010, 11:30:19 AM »
Thanks Mark.  CSV and SQL statements attached.
« Last Edit: October 02, 2010, 11:37:02 AM by tarbat »
« Reply #322 on: October 02, 2010, 12:02:11 PM »
This link is to BHX departure and arrivals board.
http://www.birminghamairport.co.uk/arrivals-and-departures.aspx
Anybody within proximity of BHX fancy putting in some time on the non-route flights coming and goings and tying them up? Takes only a little bit of practice and it's very satisfying as well as adding to our database.
M3ZVE
« Reply #323 on: October 02, 2010, 02:25:46 PM »
Thank you Mark for the origonal data and thank you to Tarbat for
the conversions.
Best regards,
Ian.
575 Feet ASL
24 NM North of EGNX
bearcat
« Reply #324 on: October 02, 2010, 04:26:37 PM »
Thanks for your lists Mark, these have filled a lot of gaps in my route database.
Stewart
flybhx
« Reply #325 on: October 02, 2010, 05:46:09 PM »
A few Birmingham flights added to the project database tonight
Chris11
« Reply #326 on: October 04, 2010, 06:50:47 AM »
I still think there should be an update team as for the aircraft. You eat an elephant one bite at a time.
Dave - is the download functionality in process?
Just one comment on the program - if you update one flight (by clicking Save) and then enter another flight number - same dep and dest but different time and then save again you overwrite the first entry - you have to click clear and then start again. Could that be changed?
« Last Edit: October 04, 2010, 07:06:21 AM by Chris11 »
« Reply #327 on: October 04, 2010, 07:53:24 AM »
I decoded 41 new alpha-numerics in & out of EMA over the weekend which, while labourious, shows that the callsign enigma can be cracked piece by piece.
The exercise also threw up some wrongly decoded flights - ie flights erroneously showing EMA as part of the route.  Not sure how we can get these removed?
« Reply #328 on: October 04, 2010, 08:38:45 AM »
There is - it's just that for routes, the team is independent of AirNav.
Quote
Not yet, I've been a bit preoccupied over the weekend (see below), plus we're only just starting to match the first takeoffs and landings, so there's not much to download yet.  If you want to download what's been done so far, it's easy enough for the time being to copy-and-paste from the route listing report into Excel.
Quote
Fair point - but there's a better way of addressing that.  I know from writing commercial web applications that users often like to see the record once it's been saved, so removing the data from the screen as soon as it's saved isn't such a good idea.  However to prevent records being overwritten, the database will now disallow changes to the Flight ID of an existing record.
Over the weekend I've captured several thousand takeoffs and landings from the network, a significant proportion (around 1400) showing blank routes, and these are in the process of being added to the database.
The distinction of being the first route to have both origin and destination derived from a captured takeoff and landing goes to Saturday morning's JZR171 (J9171), a Jazeera AW flight from Dubai to Kuwait, now safely stored in the database.
Chris11
« Reply #329 on: October 04, 2010, 08:43:39 AM »
Great - that will eliminate the overwrite of the record.
Confirm that to enter more than one route you will have to add the data, click save, click clear and then add again.
