Record 0 byte
Started by davis, March 07, 2008, 08:56:34 PM
davis
Why recordin  is always 0 bytes? I tried to put in DESKTOP--- RECORD ---IN  another folder, but always 0 bytes .. What's wrong?
gianni
Well done Gianni - I do think that you might have found a bug!
This was a problem in a pre release version of RB 2008 but it was fixed in the last version before release.  This must have crept through into the release version.
Over to you Support :-)
Noted and confirmed bug, this will be fixed. We are just waiting for any further bug reports over the next week and will work on release to update any issues arising and have that out within a 3 weeks of this release.
Aplogies, if you really need to use the recorder use 1.3 for the meanwhile.
I'm too busy watching live/network traffic, I have no time left to watch recordings :-0
davis
Quote from: AirNav Support on March 07, 2008, 09:07:55 PM
OK .. So time to make a perfect ver.1.4 and only after a few hours it is not perfect ...Still waiting
Gianni
Keep smiling Gianni - there are more than enough new features to keep you busy until the record bug is fixed - hi hi
Have you tried all the filter and export options in MyLog yet?
All the best from cold and wet England
Sorry Gianni, we aren't perfect and neither are you we are humans :)
#7
Strange, it works okay for me.  And this is something I specifically tested during beta testing.  I've been using the recording file all day today to feed into Planeplotter.
The only difference I have noticed is that there's a 5 minute delay before the recording starts - did you wait 5-minutes to see if it started recording?
tarbat, you're quite right!
I'm sure it didn't work like this before :-o
Ah yes this was done for a reason :) Too much happening today.
It was an obvious loophole in v1.3 that allowed a real-time feed into other systems.  Good to see Airnav have closed that vulnerability :(
prbflight
Recorder into PlanePlotter is working fine for me.  Yes there is now a 5 minute delay.
Paul
Roadrunner
Loophole?
Loopholes are made to be closed as are rules to be broken :-)
f6gsg
Effectively some times i have a record at 0 Bytes, not often
i try to understand when and how i can do that but it's not
systematic !!!!
More difficult to fix that bug  for Airnav.
Patrick/F6GSG
Quote from: f6gsg on March 08, 2008, 07:45:26 PM
systematic !!!!
Patrick/F6GSG
Patrick, the recording starts 5 minutes after you click "Record".
This is to stop people accessing live data by reading the record file.
It is not a bug.
