MyLog not logging all aircraft received in MyFlights
Started by freqhopping, September 02, 2010, 09:02:08 PM
freqhopping
After the program not wanting to shut down last week (the border of the application remained but everything had closed) upon restarting it I've noticed MyLog is not recording everything it should.  I noticed this because many of my alerted milair flights are not showing up in MyLog.
I figured maybe the database file was corrupted so I moved it elsewhere so the program could start fresh.  The problem continued.
I had been using a 3.13 Beta version with no problems for a log time.  So last night I installed the 3.13 final version to give it a try and I still have the problem.
MyLog is also noticeably slow to open, sort and return queries.
easy551
I HAVE THE SAME PROBLEM. Please someone reply because this is driving my crazy!
Where have you installed RadarBox and which Operating System are you using?
