Author Topic: Outlines  (Read 314267 times)
    • Rod's RadarBox Downloads
Re: Outlines
« Reply #30 on: January 09, 2011, 12:35:34 PM »
Hi Dana - no, not really - but the 3D version uses the real Google Earth, so that's the best option.
In the 2D mode, it is possible to use maps from anywhere, but they all work the same way as the NASA images - the more you zoom in, the more pixellated the image becomes. There are forum threads about how to do this, Try this as a starting point: http://www.airnavsystems.com/forum/index.php?topic=1447.msg11180#msg11180
HTH
Dana
Re: Outlines
« Reply #31 on: January 09, 2011, 03:21:55 PM »
Hi Rod,
Thank you for your information....seems to be complicated..
Thank you very much  any way :)
Re: Outlines
« Reply #32 on: January 09, 2011, 09:22:19 PM »
Dana - I feel the same as you!
Here's an outline of the GA airport very close to Denver:
Front Range - KFTG
Re: Outlines
« Reply #33 on: January 11, 2011, 11:04:28 PM »
I've been watching an RV-6 buzzing round here on the network:
Marana Northwest Regional Airport / Avra Valley Airport - KAVQ
Pinal Airpark - KMZJ including Silverbell Army Heliport (the area to the north) where Apache training (including for the British army) happens.
At Avra Vally on Google Earth I counted 6 4-engined propliners including 3 Connies, at least 13 Skyhawks, and 6 Starships. And there were 7 Albatrosses at Pinal. Davis-Monthan's just down the road, too. More rust than dust round there! (OK, I know there's not much to rust in a Starship, but you know what I mean.)
Netcop
Re: Outlines
« Reply #34 on: January 12, 2011, 06:56:14 PM »
Hi-res outlines for а few Russian airports:
- Sheremetyevo UUEE (including new terminals)
- Zhukovsky UUBW (flight tests base for Sukhoi SU95 Superjet )
- Nizhny Novgorod UWGG
Greetings from Russia, Moscow
20.54 nm NWN of UUDD
Amp: Wimo AS-1090
RadarBox24 station: Netcop
Netcop
Re: Outlines
« Reply #35 on: January 12, 2011, 07:07:43 PM »
Hi-res outline of the Hong Kong's Lantau Island
Amp: Wimo AS-1090
Re: Outlines
« Reply #36 on: January 12, 2011, 08:57:58 PM »
Excellent - our very own hi-res outlines at last!
Here's another Arizona low-res one from me:
Ryan Airfield - KRYN
Netcop
Re: Outlines
« Reply #37 on: January 13, 2011, 11:11:57 AM »
Thanks, Rod!
But I just found that your UUWB current outline is far more hi-res then mine.
So, guys, please just ignore my UUWB file from the reply #34
You may find Rod's UUWB outline as Ramenskoye.out in the outlines zip archive at:
http://rodb.gofreeserve.com/RadarBox/Downloads/AllOutlines_8-1-2011.ZIP
« Last Edit: January 13, 2011, 11:29:46 AM by Netcop »
Amp: Wimo AS-1090
vonsmalhausen
Re: Outlines
« Reply #38 on: January 13, 2011, 02:29:53 PM »
hi Rod, could you ( or someone else ) make the outline for the following Belgian airfields :
EBFN, Koksijde AB
EBFS, Florenne AB
EBBE, Beauvechain AB
i did a outline for these myself some time ago ( not realy a succes ), and tryed to improve them since, ....... but i'm just no good at it, could you please help me out here.
Thomas.
Re: Outlines
« Reply #39 on: January 13, 2011, 03:31:51 PM »
I'm happy to give them a go - as long as they are clear in Google Earth - I'll have a look...
EDIT - Blimey - they're vast! give me ten minutes... or so....
At least they're clear in GE.
« Last Edit: January 13, 2011, 07:51:28 PM by RodBearden »
vonsmalhausen
Re: Outlines
« Reply #40 on: January 13, 2011, 06:43:35 PM »
ten minutes,...... take ten day's if you need them ;-)
i'm already happy you are working on them -)
Re: Outlines
« Reply #41 on: January 13, 2011, 10:00:13 PM »
Done - not as bad as I thought! Belgian airbases:
Koksijde - EBFN
Florennes - EBFS
Beauvechain - EBBE
and a bonus extra from California
Palm Springs International - KPSP
vonsmalhausen
Re: Outlines
« Reply #42 on: January 14, 2011, 09:40:32 AM »
just installed them, great job :-)
thank you.
Thomas
Re: Outlines
« Reply #43 on: January 15, 2011, 12:24:50 AM »
It's a pleasure.
Another one, this time in the land of Oz:
Melbourne Essendon - YMEN
Re: Outlines
« Reply #44 on: January 15, 2011, 08:17:27 PM »
Durban's new airport, King Shaka International, FALE, is clearer in Google Earth, and I've noticed that some of the guesses I made last time were wrong. Here's a replacement for that, along with the separarate outline consisting of just the runway centreline. I've kept it separate so that it can be easily removed if (when) the RadarBox map gets updated.
