Outlines
Started by RodBearden, September 05, 2010, 10:45:43 AM
vonsmalhausen
FINALLY found the trick to make decent outlines :-)
i had to zoom in much more on the map.
here are 4 more Belgian airports ;
EBUL, Ursel : a former reserve NATO airfield, now used by a airclub
EBSU, St.-Hubert AB, same story
EBSH, St.-Hubert grasfield, mainly used for gliders : did the contours, buildings and rwy, as there is nothing on the RB map apart from the name
EBBX, also a former military reserve field, now used for recreative aviation
Rod, i noticed the outlines for Bertrix are "out of line" with the rwy possition on the RB map ( EBSU also, but not that much ) is there a way to correct this ? please let me know.
#46
That's better, Thomas - well done :-) As you've discovered, it's not difficult, just time-comsuming!
As to the alignment with the RadarBox runways, I really don't know whether it is the RB runways or Google Earth that is inaccurate. Obviously we can't change the RB runways, and should it be Google Earth that's wrong, devising an offset to the outline is completely beyond me.
I have noticed on a few outlines where we have had RadarBox returns, that aircraft tend to align to the outlines rather than the RB runway lines, but we know that many aircraft report wrong positions too, so I don't draw any general conclusions from that.
vonsmalhausen
3 more for today, 2 Belgian, 1 Dutch
another ex reserve field of the Belgian Airforce, Zutendaal EBSL
former main training airfield of the BAF, St.-Truiden EBST
and a Dutch airfield ; Maastricht EHBK, not a busy airport, but due to the cargo, charter and specialy the paintshop facility there, a rather interesting airport
vonsmalhausen
#48
another Belgian airfield/strip, not showing on the RB map
used to be a busy local field with several training schools (SABENA omong them), now reduced to a "recreative" airfield due to political pressure of just a couple of people.
mainly active in w.e.
Grimbergen EBGB
did the buildings in different collor (Type 29)
could somebody give me a list of the different Type collor codes, like the one's used for rwy, taxiway, markings, .....
thanks
vonsmalhausen
#49
3 more Belgian airstrips, not showing on RB map;
Kiewit_EBZH, Belgians oldest airfield, and still active
Beverlo_EBLE, Leopoldsburg-Beverlo, better known under the name Sanicole
Moorsele_EBMO, little airfield close to Flanders Fields
And another Aussie from me:
Melbourne/Moorabbin YMMB
vonsmalhausen
Chievres AB, home of the SHAPE Blackhawks
Another update for a US airport, this time for the new west runway and extension to 9/27 at Cincinnati/Northern Kentucky KCVG.
This is an addition to the existing outline.
superspotter
Hi guys;
Might be asking a bit much here but is anybody able to come up with an airport outline for Libreville, Gabon before I spend a sizeable part of the day there on monday?? kind regards clive.
Hi Clive
Will do - give me an hour or so...
superspotter
Thanks for that, I am doing Ostend-Lagos-Libreville-Leipzig on sunday/monday so I am hoping to get enough time in Libreville to leave the airnav set up for a goo few hours!
Here you are, Clive - have a good trip - I hope the internet there will allow you to share - never seen Gabon on the network before.
Libreville Leon M'ba International - FOOL
RadarBox shows the airport buildings bobbing around in the sea - hope it's not like that when you get there!
superspotter
Cheers for that Rod, I will try my best re: t'internet !
#58
An update for Nevada: replace the current outline with this.
Boulder City Municipal - KBVU
EDIT: (RadarBox knows it as what was presumably their old FAA code of 61B).
I did this because Google Earth has a new image of this airport, showing some differences and also because the RadarBox runways were very differently aligned from the previous outline. They still are, rather pointing the finger of blame at the RadarBox runways.
Note RadarBox has the runways, but doesn't know where KBVU is - it's south-east of KLAS.
vonsmalhausen
2 more Belgians
EBKH - Balen-Keiheuvel, you need to edit color type 28 for this, as i did the grasrunway in different collor ( green )
EBZW - Zwartberg
