Outlines
Started by RodBearden, September 05, 2010, 10:45:43 AM
Aerotower
Quote from: RNAGG on July 08, 2011, 02:25:18 PM
Thank you!
You were very fast!
Renato see you PM please!
#331
Here's a replacement for Marseilles Provence - LFML.
I've also done the lake it's on - Etang de Berre
Here's Djerba–Zarzis Internationalk -DTTJ
And here's Lampedusa LICD and the island (Italian, north of Djerba)
A redone outline for Goiabeiras Eurico de Aguiar Salles, Vitória - SBVT (Brazil)
A new outline:
Omsk Tsentralny - UNOO (Russia)
Netcop
Many thanks for UNOO, Rod!
Nick
Greetings from Russia, Moscow
20.54 nm NWN of UUDD
Amp: Wimo AS-1090
RadarBox24 station: Netcop
My pleasure :-)
Aerotower
Hello Rod,
Do you have anything to Angola, including a more complete map with roads, rivers, etc.?
You know something is there another side?
Thanks!
Best Regards
Hi Aerotower.
I've done an outline for Luanda airport, but I haven't got anything else.
Don't forget you can download the NASA satellite images for anywhere on Earth - that's working again now.
Aerotower
From radarbox?
It's that I have a friend who is there as you can see on my page (www.aerotower.x10hosting.com) and liked to have more detail to learn about where the planes are relatively to a point on the ground.
Aerotower
Are you saying that you don't know about NASA satellite images in RadarBox?
If that's true, try it! http://www.airnavsystems.com/forum/index.php?topic=1294.msg9667#msg9667
It works in any recent RadarBox version, whether or not you've got a network subscription.
Enjoy!
Hi Rod, thanks for resurrecting this one, I'd never seen or tried before!
#343
People do seem to forget/ignore this option. There's a keyboard shoutcut, Ctrl-d, that allows you to downoad the images while you're in full screen map view, so you can get larger images.
For clarity, I use a different set of map colours when I'm viewing the satellite images.
Aerotower
No Rod, I knew this functionality. Never used it extensively just because whenever you change the resolution of the image is blurred radarbox.
He liked to put an image from google maps for example.
