New data lost if Radarbox software crashes!
Started by andrewarles, September 10, 2010, 09:13:43 PM
Quote from: Aerotower on September 15, 2010, 12:57:56 PMWhy so many crashes ????????????????
Probably a software conflict on your PC.   My Radarbox hasn't crashed for months (or even years!!).
Have you tried another pc to see whether it happens on others?
It may be a process of elimination, try the following:
- Disconnecting other USB devices
- Updating all your drivers and applying all Windows Updates
- Stop all power saving
- Try a fresh install of RadarBox and see whether that run fine, if your RB has crashed before it may have got corrupted.
Aerotower
QuoteHave you tried another PC to see whether it happens on others?
Just got this PC, the other is still with the windows 98 and I can not change the OS.
QuoteIt May Be a process of elimination, try The Following:
Only the mouse is connected via USB.
Quote- Updating all your drivers and all Windows Updates Applying
They are all updated.
Quote- Stop all power saving
It's all off.
Quote- Try a fresh install of RadarBox and see whether That run fine, if your RB Has crashed before it got corrupted May Have.
I had done a clean install, and just kept Mylog.db3 Navdata.db3
andrewarles
All,
For the time being all is OK - apart from a scare yesterday when the files stopped jumping around, but this time I didn't loose any data when I quit and restarted the software (watching a live stream was probably the reason why it slowed down).
There is however a positive point from all this - Since I have changed the installation from the default installation to installing in c:\Airnav (as recommended by tarbat) the windows are acting much better, or normally.
Before, when you had the Db or MyLog windows open - on top of the main software window - when you went to another window, in my case Firefox on a second screen, it kept closing the window.  Now it stays open as you would expect.  Also, when the main program window was maximized it wouldn't except another window on top of it. Now it does.
Unfortunately there is a small negative point with the Map Colours.  On the map view it's impossible to change the background colour of Terrain>0ft.  It indicates black on the elevation list under Preferences, Map Colors, but it's the same colour as the sea (blue) on the map view.  It wasn't like that before.
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
Quote from: andrewarles on September 15, 2010, 01:43:59 PMThere is however a positive point from all this - Since I have changed the installation from the default installation to installing in c:\Airnav (as recommended by tarbat) the windows are acting much better, or normally.
See Airnav, you really do need to change the installer to avoid installation in the Program Files directory.
Andrew, try exporting the colour scheme, save it as "Real Radar".
I run XP on my main computer and having run run Airnav from the program files for 18 months I havn' had a bit of a problem.    May well be different for Vista or Windows 7.
orkney
hello Alan
Yes, Xp doesn't have the "virtual store" that causes the problems in the later windows so you shouldn't suffer any ill effects.
Andrew
Thanks Andrew, thats good need to check out my laptop as its Vista and I only use it for holdays, fingers crossed have not had any problems on it yet but dont want to so will move it if need be.
Aerotower
Crashed when closing and was using almost 100% of CPU.
Aerotower
Another crash, I start getting really tired. Especially for losing planes hardly turn to pick.
I need solutions !!!!!!!!!
TEDDYBEAR
Quote from: tarbat on September 12, 2010, 07:51:00 AM
andrewarles, what operating system are you running?  If Vista or Win7, and you installed in the default location (C:\Program Files....), then the databases will be in the Virtual Store.  That may be causing the problems, so you're better to install outside of the Virtual Store.  Try installing in C:\Airnav instead, and see if that solves your problems.
Secondly, what File System are you using?  Is it NTFS?
In my experience, database updates get commited to the .db3 databases every few seconds.  The .db3-journal files always remain small (<40k).  So, check you .db3-journal files in the Virtual Store.  If they continue to increase in size, then you have a file system problem.
For a description of how SQLite implements database commits, see http://www.sqlite.org/atomiccommit.html
http://www.sqlite.org/lockingv3.html
[/quoteNot quite the same regarding losing data but I had no journal files and could not find them. As I run Vista and followed the suggestion from tarbet regarding installing into C:| instead of C:|Programme Files the journal files are "singing & dancing". The only problem now is I have lost the network, the icon showing red and not connected. Have uncoupled and coupled internet connection, made sure that the McAffee is allowing data to/from anrb to go through. Any suggestions.
Teddybear
AeroTower,
We have asked you before on a few sperate occasions to contact us directly so we can check debug files so we can see whats causing your issue. Please do this.
We still believe however the crashing issue is related to either your computer setup or a computer issue. We do urge you to try it on another pc to rule computer issues out. See if you can try it on a freinds pc for a bit.
Teddybear,
Have you checked you have ticked the get network flights box? Also have you checked your network hasn't expired.
TEDDYBEAR
Air Nav Support.
Have looked in File/Preferences all boxes are ticked although I cannot find one that says "Get Network Flights". Network data was renewed on 2010/07/04 so should still be valid.
Click the network tab (next to MyFlights). Then look at the bottom left hand corner of your screen (if your flights are on that side) and you should see a tick box.
