7T-VJW
Started by ashton152001, September 18, 2010, 03:13:33 PM
ashton152001
Picked up the above going into Heathrow today and it was shown on the screen with an Angolan flag......how can i make this show the correct Algerian Flag?
Also, as a new user i am trying to work out the best way to sort the myflights screen, at present i am sorting on the changed column but it can jump about all over the place....would be interested to know what others do...
(Who is slowly getting used to the Radarbox)....
Ian,
Not quite sure what you mean 'by jumping all over the place'. Certainly the grid will be continually changing as aircraft come on and off. I only have the following columns visible:
Status, Mode S, Country Flag, Flight ID, Registration, Aircraft, Airline, Route, Altitude, Hdg and Squawk in that order. If you go into File>Preferences you can tick/untick the grid visible columns.
Ian - the Changed column entries in MyFlights change second-by-second - no wonder it's jumping around - you would be much better sorting by something more stable, like Mode-S, Flight ID or Registration.
I know some people like to sort by distance or altitude - I'm a Flight ID man myself to keep fleets (and logos) together.
ashton152001
Thanks for the replies....much appreciated
