Timeout flights not clearing
Started by flybhx, November 01, 2010, 08:38:59 AM
flybhx
I am having a problem at the moment where flights that have timed out are not disappearing from the map and myflights after the assigned time period.
Is there any way of clearing the list?
What version are you using?
The only cases of this happening is when your machine is being overloaded and RB starts to do funny things. Check Task Manager and tell us what your CPU usage is when RB is runing under normal conditions.
flybhx
I'll check the normal cpu when I get back home. If it helps at all I get about 30-40 at most on my list at home. The problem occurred whilst at London Heathrow with over 100 flights recording and a lot displaying on the map in a confined area
